Old 12-18-2018, 10:03 PM   #1
erniet's Avatar
Squeaky entrance door
I think it is my entrance door vs. my screen door that makes an irritating 'squeak' while driving down the highway most of the time.
I tried adjusting the door, also made sure neither lock is causing the sound. I've lubed the latch and stud it engages on.
Any ideas will certainly be appreciated as we are looking at a 2500 mile trip in a week.
Thanks.
2014 Berkshire 400QL; sometimes towing 2007 Silverado and other times
towing my 20' Aluma trailer with a vehicle on it.
erniet is offline   Reply With Quote
Old 12-19-2018, 11:21 AM   #2
Mmnsc's Avatar
Join the club they all seem to squeak. Try to put a small piece of adhesive foam insulation at the top and bottom of the frame with the locks on it. Putting outward pressure seems to reduce the squeak.
Mmnsc is offline   Reply With Quote
Old 12-19-2018, 09:29 PM   #3
CZNEDY's Avatar
Never mind the squeak, you can fix that. Tell us about your 2500 mile trip! Where you going?
2018 BERKSHIRE 34 QS
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 12-20-2018, 12:15 AM   #4
erniet's Avatar
I plan on leaving WI in 8-10 days headed for Quartzsite, AZ. I don't make the shortest trip so with all of my side trips it will be right at 2,500 miles to get to Quartzsite. Then from there I bounce around AZ every week or two to different locations. Don't plan to arrive back in WI until very late March or early to mid April.
Old 12-20-2018, 09:05 AM   #5
edgewant's Avatar
I chased an annoying rattle/squeak for two months on my 2013 390RB. It seemed to be coming from the latch side of the door. After many attempts I finally found it to be the fender liner brace that attaches to the body near the door frame. There are two self tapping fasteners that are covered by spray in foam. They had backed out and were causing the squeaking.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 12-20-2018, 10:09 AM   #6
erniet's Avatar
Thanks, I would never have thought of looking there. Definitely will check.
door
