Old 09-20-2016, 07:56 PM   #11
KennyGolub's Avatar
Originally Posted by stevelah View Post
Are you hooked up to shore power do you have the generator running
I tried it both ways. I measured 120v at the outlet too.
Thank you for the reply.
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Northern Ohio
KennyGolub is offline   Reply With Quote
Old 09-20-2016, 09:00 PM   #12
stevelah's Avatar
Sounds like your washing machine is broken
Steve
40XLBH 2015
stevelah is offline   Reply With Quote
Old 09-20-2016, 09:01 PM   #13
Mmnsc's Avatar
Kenny
Do you have the water pressure on to the washer? Some machines require water pressure to start. My wife just got a new washer at home and nothing would work until she realized the water was not on. If you blew the lines out with air first, that might be part of the issue. Just a thought to check out. If you pump the pink stuff through with the water pump that might work.
Good luck
Marty
Mmnsc is online now   Reply With Quote
Old 09-21-2016, 07:12 AM   #14
KennyGolub's Avatar
Originally Posted by Mmnsc View Post
Kenny
Good luck
Marty
Thanks. I had the same thought and connected water to the coach, but same result.
As said above, me thinks it's broke.
Thanks, all, for the replies.
Ken & Laurie
2016 Chevy Colorado
Northern Ohio
Old 09-21-2016, 07:49 AM   #15
I-RV's Avatar
Ken, I presume that you checked out the electrical outlet; like with a night light?
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 09-21-2016, 09:22 AM   #16
stevelah's Avatar
This may be another idea that might not help you either but on the front of our Whirlpool stackable washer dryer on the front of the washer there's a little reset button on the front of it did you try that.
Steve
40XLBH 2015
Old 09-21-2016, 03:13 PM   #17
KennyGolub's Avatar
Hank
I measured the voltage at the outlet with a meter.
Thanks !!
Ken & Laurie
2016 Chevy Colorado
Northern Ohio
Old 09-21-2016, 03:14 PM   #18
KennyGolub's Avatar
Any chance I could ask you to snap a photo of that ?
I didn't notice one.
Thanks,
Ken
Ken & Laurie
2016 Chevy Colorado
Northern Ohio
Old 09-21-2016, 05:17 PM   #19
stevelah's Avatar
Steve
40XLBH 2015
Old 09-21-2016, 05:18 PM   #20
stevelah's Avatar
Little button with the X on it probably won't help you probably already tried it.
Steve
40XLBH 2015
