Old 01-07-2015, 12:07 AM   #1
RKC02's Avatar
Starting in Very cold weather
Per the manual I do not start/run my engine until ready to travel. Our plans have us leaving this Thursday morning and the forecast is for -15 temps with the wind chill. I have the block heater plugged in. My question is wether I should start it for awhile the day before just to lube things up or just let it go until travel time? I have no idea as to which way to go and need some big Berky advice!
RKC02
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
Old 01-07-2015, 05:37 AM   #2
2014 360 QL
po 185's Avatar
start it the day you leave and let it idle for about ten min. to get the turbo warm. then go slow till everything gets warm, ( engine and tran.)
po 185 is offline   Reply With Quote
Old 01-07-2015, 05:46 AM   #3
The biggest question is do you have blended fuel in the tank. At -15 if you do not your fuel will gell.
lbrunning is offline   Reply With Quote
Old 01-07-2015, 06:56 AM   #4
I-RV's Avatar
Should the engine block heater be used prior to starting. I haven't used it, but believe that it needs to be plugged in (at the rear compartment), probably turn the circuit breaker and have either shore power or generator on. Is that correct; I am heading south in two days?
Hank
I-RV is offline   Reply With Quote
Old 01-07-2015, 07:47 AM   #5
Campin Cajun's Avatar
Yes, plug in your block heater the day before and leave it plugged in until you are ready to start the engine.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 01-07-2015, 07:56 AM   #6
CAT-RN's Avatar
On my Berkshire you can turn breaker on under the bed & plug heater in at the rear compartment. Assuming you are on shore power this will work
You can also just run an extension cord and just plug in the block from shore power. Overnight be more than adequate but will work fine. Three or four hours be ok.
Russell
CAT-RN is online now   Reply With Quote
Old 01-07-2015, 08:19 AM   #7
KyDan's Avatar
If I were getting ready for a big trip in weather that cold I would definitely start it the day before and let it run long enough to get warmed up.
If it's not gonna start you want to know that a day early!!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 01-07-2015, 09:35 AM   #8
NV245's Avatar
I have not driven an air brake vehicle in weather that cold, so I wonder if frozen air lines are a concern and how to determine if it is safe to travel.
NV245 is offline   Reply With Quote
Old 01-07-2015, 11:53 AM   #9
BooBoo23's Avatar
If you aren't running #1 diesel you best get some fuel conditioner put in the tank as -15 will surely gel. As for air lines you should have an air dryer in the line to take care of that and drain you tank regularly or have a bleeder on the tank.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 01-07-2015, 05:34 PM   #10
ernest917's Avatar
Should you plug in hoe engine heater if the temp gets into the teens ?? Not going anywhere but have wondered if it's a good practice to just plug in the heater when it gets that cold....
ernest917 is offline   Reply With Quote
