Old 05-07-2016, 08:40 PM   #1
edgewant's Avatar
Steering gear box woes
A hard clunk in the steering started happening a couple of weeks ago. Was pretty sure it was the gear box and thought the input shaft bearings were failing. Took it to an Oasis service center in Ringold Ga. They took about 3 hrs to identify and repair the gear box. Several box bolts that hold the gear box together had backed out and created slop in the shaft. They had to dismount the box in order to access the bolts that were against the frame. Torqued them to spec and that solved the problem. Cost me $500 for labor but was happy to get it repaired. Cornerstone RV extended warranty didn't pay a penny. Not real happy about that.
2013 Berkshire 390RB-60
Toad: 2002 Jeep Wrangler
edgewant
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 05-08-2016, 07:44 AM   #2
I-RV's Avatar
edgewant - You recently reported that your steering greatly improved after you replaced the bell crank. I'm just curious that after the steering gear box was fixed, did they calibrate the gear play and has your steering even improved from what it was. Sorry that you had the breakdown.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 05-08-2016, 07:59 AM   #3
I-RV's Avatar
edgewant - Were you just beyond the 3 yr. Freightliner chassis warranty?
Hank
Old 05-08-2016, 08:25 AM   #4
edgewant's Avatar
Freightliner did not adjust lash. I didn't see a problem with it. You can watch stick your head out the drivers window and there is little or no free play. And yes I went out of warranty in February.
edgewant
Old 05-08-2016, 11:04 AM   #5
I-RV's Avatar
Does the warranty start when you take possession?
Old 05-08-2016, 11:57 AM   #6
Yes
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
Paulie Boy is offline   Reply With Quote
