Old 10-01-2016, 07:42 PM   #1
Step and Aisle Light Bulb
Has anyone replaced a Step or Aisle Bulb?
If yes where did you purchase the bulb?
My bulbs look like a AGC Fuse. The numbers on the bulb are 14V and 4W.
Pat
Cudntherd
2011 Berkshire 390BH-60
cudntherd is offline   Reply With Quote
Old 10-02-2016, 09:01 AM   #2
Replaced our aisle and step bulbs about two years ago with LED from: https://www.superbrightleds.com/cat/...acement-bulbs/
I believe the style was called "Festoon Base" - just match up the size to find the correct bulb. F30-WHP-12V bulb fit ours - they are 30mm.
The design of the fixture makes it just a little tricky seating the bulbs but LED works great and should last many years. Ended up replacing the rest of our house/basement bulbs with LED from the Cabin Bright booth at the FROG rally this year.
Hope this helps
jandp is offline   Reply With Quote
Old 10-02-2016, 02:38 PM   #3
Steps bulbs and bought them at camping world Tampa they were hard to find Jim
jrlebaron is offline   Reply With Quote
Old 10-03-2016, 08:24 PM   #4
I just bought and installed these last week. They work great. One note...if you install and they don't work, flip bulb 180 degrees and reinstall.
https://www.amazon.com/dp/B00Z6K65XK..._YrW8xbCA3148N
-David
trekdave42 is offline   Reply With Quote
Old 10-04-2016, 05:36 AM   #5
dan-nickie's Avatar
-David
I used the same ones. Note that they are quite a bit brighter than the original.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 10-08-2016, 10:05 PM   #6
Thanks for all of the reply's.
I ordered, received and installed F30-WHP-12V from superbrightleds.com.
They work great.
Pat
Cudntherd
Old 10-11-2016, 06:49 PM   #7
fredhardy's Avatar
Thaightnks for all the info. I just ordered 2 bulbs for SuperbrightLEDs.
Regards,
Fred
Fred Hardy
Phoenix, AZ
2014 Berkshire 390BH-60
2007 Explorer Sport Trac
fredhardy is offline   Reply With Quote
Old 10-11-2016, 06:50 PM   #8
fredhardy's Avatar
Thanks for all the info. I just ordered 2 bulbs for SuperbrightLEDs.
Regards,
Fred
Fred Hardy
Phoenix, AZ
Old 10-11-2016, 10:05 PM   #9
Sorry I did not see the previous post on polarity
Pat
Cudntherd
Old 10-16-2016, 08:45 PM   #10
fredhardy's Avatar
Got my new bulb installed and it works great. Thanks for all the input.
Regards,
Fred
Fred Hardy
Phoenix, AZ
light
