Originally Posted by bborder
Gordon- having the same issue here. How did your repair hold up?
My repair is working fine after a month of use.
If you need the repair, I think the second solution with the angle iron would be easier and potentially more durable. You would wind up with some exposed screw heads on the inside of the inside steps, but that is just a cosmetic issue.
— Gordon
