Old 12-19-2015, 07:34 PM   #51
And make sure the rubber seal is in place. Last trip I made I hooked up a 5 footer that I hadn't used and when I dumped the gray water I saw I was leaking on the dump valve side. The rubber gasket was missing.
poppytoymaker is offline   Reply With Quote
Old 12-20-2015, 06:01 AM   #52
Originally Posted by stephencamiolo View Post
Thanks Campin Cajun that's exactly what I was looking for! This will be my first project when I get to Ocala!
Where are you staying in Ocala? We'll be at Wilderness through January.
Paul
Paulie Boy is offline   Reply With Quote
Old 12-20-2015, 08:36 AM   #53
stephencamiolo's Avatar
We'll be on a private horse farm off 90th ave where my daughter trains. We'll be arriving Jan 10
stephencamiolo is offline   Reply With Quote
Old 12-20-2015, 09:11 AM   #54
klucas's Avatar
Originally Posted by Campin Cajun View Post
Good idea klucas. I never thought about cutting to opening larger.
I cut it a few inches wider and about 12" longer. I can fit the entire hose and both elbows in that compartment now. Prior to me cutting it a bit larger it was useless.
klucas is offline   Reply With Quote
Old 12-20-2015, 09:41 AM   #55
Great idea, can you attach a pic?
Is there enough room to store the head (on/off) valve of the Lippert system?
Old 12-20-2015, 09:46 AM   #56
klucas's Avatar
I store this set up and an extra elbow for the attachment to the coach. Put your hand in the small opening and you will see how much room is in there. My coach is in storage so I can't get pics for a while.
Name:   ImageUploadedByForest River Forums1450626355.768842.jpg
Old 12-20-2015, 03:41 PM   #57
I doubt there is room to store the head of the Lippert system. I have that as well and it is a pain to store. I live the system. I store mine in the water bay with the hose tucked behind the filter housing.
