12-13-2015, 05:13 AM
Stinky Slinky...
After 4 months my RhinoFLEX system is starting to leak at both ends....drips from where hose connects to the ends....gross! Anyone have a system they like and would recommend, or is this just a every 4-6 month purchase?
Thanks all!
--Nathan
2016 38a
--Nathan
2016 38a
12-13-2015, 06:40 AM
2014 360 QL
I have used my Rhino Flex system for about 3 years now and I have not had any trouble with drips at the ends. the last time was this year I was at a camp for 6 mo.
2014 360 ql
12-13-2015, 07:13 AM
When you buy a NEW Rhino Flex the (VERY First) thing you must do is Look in each end,if the cut off Flap is Protruding in the Exit area Unlock the Fitting and unscrew the Hose! Take a Tin Snip and Cut the Obstruction from the end of the Hose! Now Screw the Hose back into the Fitting until it is Bottomed Out,now thread the Locking Collar until it LOCKS the Fitting! This step will prevent (4) things, Hose pulling out of fitting/Hose leaking at fitting area/Crap on the inside Flap/ Owner getting REAL MAD,when any of the above Happens! Youroo!! PS These are NOT Plug & Play ready to Use when you buy them!
12-13-2015, 07:57 AM
Sure wish I would have known that! Mine leaks at both ends also, not impressed.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
12-13-2015, 08:28 AM
Ours is 3 1/2 years old 1 year in the same place no leaks and still using it. The other one we had lasted less than 6 months. I second the trimming of the hose and making sure the hose is seated on the fittings.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
12-13-2015, 09:18 AM
Nathan, you can take the ends off the hoses, clean and apply a coat of Vaseline on the hose, this will lubricate and also helps seal that area.
Youroo, has some good advise also.
2013 Berkshire 390BH
Y'all are brilliant! Just went and looked inside the ends (not my finest moment). Both ends the hose is all the way screwed into the fitting HOWEVER, there is a significant 'hang nail' on both ends!!! I will not be repairing this hose! Closed the grey valve and threw the hose away! Will pick up fresh new one this morning and begin trimming away!!! Thanks again fellas!
--Nathan
2016 38a
--Nathan
2016 38a
12-13-2015, 09:24 AM
....and a big tub of Vaseline! Thanks Cajun!
--Nathan
2016 38a
--Nathan
2016 38a
12-13-2015, 10:01 AM
I would be hesitant to use Vaseline on plastic parts and never on rubber parts since it reacts with many of them. Instead I would use the silicone grease you can buy in the plumbing department and is designed for this type of application.
12-13-2015, 10:05 AM
This information would have been good to know back in my younger days. :-)
Dan
2014 Berkshire 390RB-60
12-13-2015, 12:06 PM
Stinky Slinky...
Then don't use it. Do you know what rubber, plastic and Vaseline have in common?
12-13-2015, 12:10 PM
I know Cajun I know..... They're all going on my new stink slink!! 😉
--Nathan
2016 38a
--Nathan
2016 38a
12-13-2015, 02:14 PM
Originally Posted by nathantoensing
I know Cajun I know..... They're all going on my new stink slink!! [emoji6]
--Nathan
2016 38a
Hahahaha hahahaha.......that's funny, also they are ALL a product of crude oil. They are compatible.
12-13-2015, 05:22 PM
That may be Campin Cajin, but they are modified. When i worked for Xerox there was a special lube for plastic gears if you used vaseline or other petroleum products they became brittle. Just like nylon in parachutes if a petroleum product came in contact (oil) they were condemned it weakened the nylon even though it came petroleum. I worked in the parachute industry over 40 years.
Ham KG5LTL.
12-13-2015, 05:37 PM
Sorry to steal the thread, but "parachutes" reminded me of these words of wisdom. I didn't pack parachutes, but I WAS one of those "just sailors"working on helicopters.
2011 Traverse LT, 3.6L, FWD
12-14-2015, 08:47 AM
Actually they aren't. Petroleum Jelly is hydrocarbon based as are many plastics and rubbers. This is part of the reason it damages rubber seals and some plastics. Silicone grease on the otherhand is not hydrocarbon based and is formulated such that it does not damage rubber.
You can go ahead and put Petroleum Jelly on whatever you want. Depending upon the formulation of what it is applied to it might be ok. I on the otherhand would rather spenp a couple of bucks and buy a product designed for the application and not have to worry about it.
12-14-2015, 08:53 AM
2016 38a
Nathan,
OR... consider getting a Lippert WasteMaster. Yes, it is more expensive than a Rhinoflex but, in the 1 1/2 years of using this system not ONE leak or problem. This is the best Stinky Slinky out there!
Amazon.com: Lippert 359724 Waste Master 20' Extension RV Sewer Hose Management System: Automotive
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
12-14-2015, 09:27 AM
BamaBob, this looks like the way to go. I picked up a new one yesterday but think I'll keep it as backup and get this one!!! Thanks much!
--Nathan
2016 38a
--Nathan
2016 38a
12-14-2015, 10:16 AM
Originally Posted by BamaBob
Hi Bob,
Thanks for for the link. Now my Christmas shopping for Rick is done! Because you know, nothing says Merry Christmas like "Here's a new poop tube"!!
And Cajun: we have used PJelly for years too. No problems ever.
Karen
Karen and Rick
2020 Forester 2251SLE
Previous: 2018 Berkshire XL 40C
2011 Honda CR-V toad
12-14-2015, 10:26 AM
Oh Karen.... In our short tenure as full-timers I've come to learn there's nothing more exciting to RV'ers and discussing waste management. Example: I'll mention my macerating toilet and it's like telling them I have a 1,000 doughnut holes they can jump into! I've given more demonstrations of my toilet than any other part of the coach!!! It's like Haley Davidson people.... They only discuss their 'pipes'. 😜
--Nathan
2016 38a
--Nathan
2016 38a
