Old 11-24-2015, 04:56 PM   #21
accumack's Avatar
I don't know what the problem is dumping with the regular hose. I've had no problems but I see can several with the small hose and macerator.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 11-24-2015, 05:52 PM   #22
Lots of advantages. First is being able to pump the poo up hill. If you have a sewer clean out at your house you can use it to dump the tanks at house instead of at the campground. Storage would also be a advantage as the hose is mote manageable. I'm sure others have more but the biggest is dumping at the house.
Old 11-24-2015, 07:02 PM   #23
accumack's Avatar
I have a RV hookup at our winter home with sewer and 50 amp electric.
Ham KG5LTL.
Old 11-24-2015, 07:04 PM   #24
Me too.
Old 11-24-2015, 07:51 PM   #25
Campin Cajun's Avatar
I can go either way on this one. It has advantages and disadvantages, just like the 3" hose.
It's kinda like a Ford vs Dodge, people gonna like what they like. I would like to see it as an option on the Berks though.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-24-2015, 08:31 PM   #26
If one came on the unit, I'd probably use it, but I wouldn't give 15 cents for it otherwise. In none of my camping situations in the last 45+ yrs have I ever seen a need for one.
Old 11-25-2015, 10:52 AM   #27
BamaBob's Avatar
Even though it is a bit "Dramatic," the Thetford video on the Sanicon-turbo makes the point I was attempting to stress - loosing the Logistics tail you have with a regular sewer hose (3" hose, hose support, extension and, in the case of a WasteMaster a bayonet adapter)
Sani-Con® Turbo | Products | Thetford
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 11-25-2015, 11:37 AM   #28
B and B's Avatar
Not a Berkshire owner but I do enjoy the information in this thread. I am looking for a way to dump at home and this will do the job for me. Thanks for the idea.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-25-2015, 12:42 PM   #29
Hi sorry about the lunch debacle. If you watched the full video it showed that the previous owner of the motor home had put some disinfectant wipes in the black holding tank. This is what plugged up the blades of the macerater and caused the unit not to function. The point I want to make is you need to be careful what enters the black water tank will meet the design limits of the equipment.
This video is one of many you tube video the author has on his adventure to Alaska. It starts with buying his first motor home and journey to his work camp in Alaska. Most of the videos are informative and entertaining. If you want to watch more go to chris travels north to Alaska.
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 11-25-2015, 01:12 PM   #30
BamaBob's Avatar
Hope this helps Tim
Tim,
Thanks -- and no worries on the lunch and video -- a Military Career living out in the boonies cured me of ANY squeamishness
I saw the part about what gummed up the works - with relief I must add, because I was concerned the unit may be poorly designed.
I wonder who I could ask to find out if the so-called "Flushable" moist wipes would exceed the design specs of the Thetford?
Finally, I did discover his series after looking at that video - GREAT info since we plan on going to Alaska in 2018!
Another good source of videos andf general info on fulltiming/traveling the country can be found at this couple's website:
Gone With the Wynns
berkshire
