Old 07-23-2015, 11:17 AM   #11
Do you guys have the number for randy at equalizer?
-David
trekdave42 is offline   Reply With Quote
Old 07-23-2015, 01:14 PM   #12
jacks down
had the same thing happen to me---thank goodness was able to call service dept at MHS at Alvarado. Was told to recycle the odd looking circuit breaker located near the batteries. would still be sitting there if the service dept had not been open. NOTHING about this in the motor home manuels
FR3 owner
Lfrazee is offline   Reply With Quote
Old 07-23-2015, 07:43 PM   #13
Just google equalizer. It's an 800 number in Elkhart.
Paulie Boy is offline   Reply With Quote
Old 07-23-2015, 07:50 PM   #14
I-RV's Avatar
Originally Posted by dan-nickie View Post
Great to hear.
Since your pump was not working, I assume your slides were not working either?
Whew! Home at last. That Power-One that my son got me for Father's Day was a life saver. Here is a link to it.
PowerAll Deluxe Series
I was about to do the cordless drill thing to turn the pump. Has anybody ever done that? Now I have to find out why there is no power to the pump and keypad, why the keypad lights go crazy when the ignition is turned on, and why I am losing a lot of hydraulic fluid I do monitor the fluid regularly and it stays good. But all of the sudden I am down about 3-4 qts.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 07-23-2015, 07:54 PM   #15
accumack's Avatar
My hydraulic pump leaked at the junction of the pump body and the aluminum manifold it turns out it was missing an o-ring. Installed it no problems.
accumack is offline   Reply With Quote
Old 07-23-2015, 08:30 PM   #16
I-RV's Avatar
Thanks accumack, I do have a lot of fluid on the shelf. I will have to check that out.
Old 07-23-2015, 08:34 PM   #17
accumack's Avatar
Also check your control panel I found a wire that was pushed back into the plug. I corrected that also.
I grew up in Lumberton N.J. next to the Burlington County Airport
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
Old 07-24-2015, 06:37 AM   #18
fr3 owners, you definitely need to find and identify the bar circuit breaker located near you coach batteries-- if it kicks out , controls your jacks and also your refrig. and maybe more. I have had to reset it once to get my jacks to come up and once to get my refrigerator to come on.
Old 07-24-2015, 01:29 PM   #19
I-RV's Avatar
This is not a Bingo , but an all-***t. After being back home and parked next to my home, the power came back on to the hydraulic system.
I'd rather have no problem or a totally out problem. Even the professionals have trouble repairing intermittent problems.
jacks
