Old 09-19-2015, 02:01 PM   #1
marialee-Berkshire410qs
marialee's Avatar
Suburban SF42F furnace
Furnace fires up for 1/2 min. Then shuts down. Can I fix this? Thanks
marialee is offline   Reply With Quote
Old 09-19-2015, 02:53 PM   #2
Could it be the thermostat is not calling for heat ? Not sure the temps of where you're at.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 09-19-2015, 03:06 PM   #3
marialee's Avatar
Had thermostat set at 72 room temp was 62.
Old 09-19-2015, 03:14 PM   #4
The first thing to look at is the exhaust. Make sure there is nothing blocking it. Can you hear it trying to start, the clicking of the igniter?
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 09-19-2015, 03:15 PM   #5
Campin Cajun's Avatar
Check that the fan is on auto.
Wow, 62, I would love some weather like that.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 09-19-2015, 03:58 PM   #6
marialee's Avatar
Gas forced air furnace, no fan adjustment. Nothing blocking input or output. It ignites but shuts off quickly.
Old 09-19-2015, 04:55 PM   #7
The fan adjustment is on the thermostat. Double check the fan speed when you are on furnace mode on the thermostat. Auto is the preferred speed for everything.
Paul
Paulie Boy is offline   Reply With Quote
Old 09-19-2015, 05:33 PM   #8
marialee's Avatar
Our thermostat only gives choices for fan speeds on the air conditioning and heat pump modes. The furnace was working fine the day before.
Old 09-19-2015, 05:48 PM   #9
Could be the thermocouple is bad. When the furnace lights, the flame heats the thermocouple, which expands the gas in it, and applies pressure to the gas valve, which keeps the gas flowing. If it doesn't apply the pressure in 30 sec or so, the gas valve closes (at least I think that's how it works). So there are 2 issues I know of: 1) If the flame isn't heating up the thermocouple, the gas valve shuts down. Check to see that the flame is engulfing the thermocouple. 2) If your MH or heater is somewhat older, the flame may have burned through it. This seems less likely, as the thermocouple in my old home furnace used to last several years with a pilot light continuously heating it. I highly doubt your MH furnace has that much use on it.
2011 Traverse LT, 3.6L, FWD
Old 09-19-2015, 05:48 PM   #10
39 degrees here this morning in central Colorado at 8K feet elevation. Leave for Moab, UT week from Monday, ; much lower elev and somewhat warmer. Still, winter IS coming. Yuma by early November.
Boowho??
boowho is offline   Reply With Quote
Old 09-25-2015, 07:25 PM   #11
marialee's Avatar
Solved the non working furnace problem. Yeah!! Before fixing furnace the Fantastic Fan also stopped working. Found out both units are on same fuse. Checked out fuse it was good. Looked behind panel pushed in corresponding wire, it was loose. Problem solved. 😊
furnace, suburban
