Old 03-03-2014, 06:18 PM   #1
2014 360 QL
po 185's Avatar
surge protector
ok iam new with a motor home,,,always had a 5 wheel so iam asking about a surge protector for my motor home...what ones is the best ? it will seems that I will be hooking up on 30 amp most of the time but some places I can have 50 amp,,
I have a 2014 360 ql
so all the help will be great
po 185 is offline   Reply With Quote
Old 03-03-2014, 07:48 PM   #2
Berkshire 390QS
NO3putt's Avatar
Purchased a Progressive 50 hard wired surge protector with remote for our Berkshire. They work with any amps, 30 or 50. Recommend you get a 50amp.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 03-03-2014, 07:52 PM   #3
TURBS's Avatar
progressive industries hardwired or a franks autoformer.
Either way thats the only two i would recommend!
Old 03-03-2014, 08:05 PM   #4
Triguy's Avatar
Match the amps to your RV. 50amp gets the 50amp protector.
The Progressive's are very good. I've got the 30amp EMS-PT30C, but you would want either the EMS-LCHW50, which is hard wired or the EMS-PT50C, which is portable. Both of those protect against much more than just surges.
I would get the hard wired unit if I owned a motorhome.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-03-2014, 08:45 PM   #5
chicagoslick
chicagoslick's Avatar
Progressive 30amp w/ remote display hardwired...Everywhere I looked the Progressive was highly rated...
Gary, Tonia, Baile, Summer and Otis our Boston T.
Flagstaff 27RLWS Emerald Pkg
2015 Ford F150 King Ranch FX4 Max Tow 3.5EB, 3.55
Equalizer 4 WDH, 1,200 / 12,000Lbs
chicagoslick is offline   Reply With Quote
Old 03-03-2014, 09:44 PM   #6
X5 on Progressive Industries EMS unit. Link: Progressive Industries
Old 03-04-2014, 08:10 PM   #7
X6...... The Progressives protect against MUCH more than simple surges. For example, open neutral, which will put a full 220-240 volts into every one of your appliances. POOF, everything ruined.
Also, I would get the one that mounts inside, not the external one that hangs on the power pedestal. Less chance of it sprouting legs and sneaking off in the dark of the night. I mounted my own in less than an hour.
Boowho??
boowho is offline   Reply With Quote
« Goshen | Inverter »
