Old 09-02-2015, 02:45 PM   #91
15berkxl's Avatar
Kenny I left my in the inverter compartment as well tie wrapped it to the cage in front of inverter so it is visible when I open door. I thought about putting it inside but could not figure out the best way to run it.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 09-02-2015, 02:47 PM   #92
Originally Posted by Paulie Boy View Post
By the way, make sure breakers are off when you plug the power cord in. For some reason if the breakers are on when you plug the power cord on the EMS has heartburn and acts all weird.
Paul
A good idea either with or without the EMS.
Boowho??
boowho is offline   Reply With Quote
Old 09-02-2015, 02:49 PM   #93
15berkxl's Avatar
Kenny, I left my monitor in the inverter cabinet. It seemed like the most appropriate location to view when you hook up the power cord then switch the breakers on. By the way, make sure breakers are off when you plug the power cord in. For some reason if the breakers are on when you plug the power cord on the EMS has heartburn and acts all weird.
Paul
Paul weird how? I plugged my coach in with breaker live and it did a check I am guessing and then the contractor clicked in. That was the first time it had ever been energized do I didn't think anything of it.
Wayne
Wayne
Old 09-02-2015, 02:51 PM   #94
Originally Posted by KennyGolub View Post
I just wired the progressive in my Berk.
Has anyone ran the remote wire into the coach? If so, can you tell me/post pics of where and how you got it in ?
Thanks,
Ken
I haven't done it, but plan to. If the power completely fails, I'd be able to deduce whether it was a full "hard" power failure or a temporary condition being handled by the EMS.
Boowho??
Old 09-02-2015, 02:53 PM   #95
15berkxl's Avatar
I learned something of the coach today from the Progressive unit front AC is on L2 and pulls 16A and rear is on L1 and pulls 14A.
Wayne
Wayne
Old 09-02-2015, 02:53 PM   #96
Wayne
It's doing exactly what it's supposed to do. You plugin, wait about 10 seconds and the relay pulls in (loud click) . If there's a problem, the relay is quiet and you'll get an error code.
The breaker being off just lessens the chance of something going wrong. Not necessary all the time, but a good habit to get in to and takes no extra effort at all. For that 1 time out of a 1000 where a problem might occur.
Boowho??
Old 09-02-2015, 03:26 PM   #97
15Berkxl,
The one time I plugged in with the breakers in the on position the EMS shut everything down. Switched the breakers off and then on and the EMS went through its cycle and then let power into the unit.
Paul
Paulie Boy is offline   Reply With Quote
Old 09-04-2015, 05:57 AM   #98
Fulltime in our Berkshire
KennyGolub's Avatar
Breakers?
What breakers is everyone talking about ?
Did I miss something on my install ?
Ken
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Home is Where we park it
KennyGolub is offline   Reply With Quote
Old 09-04-2015, 08:26 AM   #99
dan-nickie's Avatar
Ken
They are just talking about the Breakers at the campground pedestal. You do make sure they're turned off before you plug in don't you?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 09-04-2015, 09:14 AM   #100
KennyGolub's Avatar
Now that I think about it, I can't think of a time where they were on when I got there, so I never imagined that's what was being discussed.
I will now make a mental note that if they ever are on to make sure I turn them off first. (sure hope I have enough brain cells left. Getting scarce)
Thanks for passing on that info !
Ken
Ken & Laurie
2016 Chevy Colorado
