11-29-2018, 07:42 AM
Suspension lowering after a couple of days while parked
Has anyone had this problem , i have a 2018 Berkshire XL , and after being stationnary for a cople of days my suspension lowered itself .
Also once i have started the RV and gave it time to re level the suspension , the rh frt is not as high as the left hand side can barely pass my
fist between tire and wheel opening.
Any ideas ??
Mike
11-29-2018, 08:06 AM
I believe leak down in a couple days is normal. Mine does and previous discussions here have shown that others do also.
As far as the front being out of level, you may need the ride height adjusted. Do you know if it is still out of level after being driven?
Dan
2014 Berkshire 390RB-60
11-29-2018, 08:16 AM
Thanks for the quick response , yes its still the same , will look into getting it adjusted.
11-29-2018, 08:25 AM
FYI I had mine adjusted the first time under warranty at no cost.
Dan
11-29-2018, 08:28 AM
[emoji6] [emoji6]
11-29-2018, 08:39 AM
Freightliner's factory center in Gaffney SC can easily handle your adjustment - but, of course, any Freightliner facility should be able to as well.
I find that my coach will also lose it's bag air the longer it sits, with the bags left inflated when parked, and no legs down. Of course, when we park with the legs down, we deflate the bags beforehand anyway, if not automatically - our coach allows either way.
The Turners...
11-29-2018, 09:33 AM
11-29-2018, 10:55 AM
Before you go and try to bring it in for service, try this:
air the coach down but don't let the jacks go down all the way. Restart and let the coach air up.
Shut down, retract all jacks and restart. let the coach run for a while and see if that gets you back to normal.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
11-29-2018, 11:10 AM
Dragonship Captain
That works if the suspension is not getting ANY air.... it's ONE valve into the system. If there's air, there's air to all of it.
Meanwhile to the OP.... I would drive it first, and then come to a nice straight stop on level ground (say a Wallymart parking lot) and see if you're REALLY out of level.....
As for the science here.... there are THREE ride height valves... IIRC two on the front and one on the rear or vice versa..The axle is connected to them with rods and the valve either lets air in or out of the bag depending on height. Get under there and find them and see if there are any obvious problems with the rods as they are somewhat delicate little things... Do an image search for: https://www.google.com/search?q=rv+r...w=1429&bih=766 and you'll see a bunch of different ones to give you an idea of what you're looking for.
If one is in fact out, they are not hard to adjust. Get the distances from FL, it's down to the 1/2-1/4"
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
11-29-2018, 11:15 AM
Ok will try and give you feed back.
11-29-2018, 03:08 PM
Two on front, one on back. This is what they look like.
Dan
11-30-2018, 10:36 AM
When you find them it doesn’t hurt to give then the soap test just in case the valve is going bad or leaky connection. I’ve had to replace two, both passenger side front.
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
11-30-2018, 10:40 AM
Thanks , will find them and test them.
12-13-2018, 08:02 PM
Had freighliner look at it , and their was a problem , they replaced the complete system.
Mike
12-13-2018, 08:06 PM
Mike
Not sure what you mean by complete system, but I did have both of my adjusters replaced within the 1st 6 months.
Glad you're back in business.
Dan
