Old 10-14-2014, 09:36 AM   #11
JTN8's Avatar
They were all tight from what I could tell. Just drove it 600 miles round trip to Charlotte for the race and it makes the noise still when hitting the brakes. Other than that rides fine and no noise... Sounds like definitely something in the suspension but not sure...
Old 10-14-2014, 12:30 PM   #12
Had a front shock absorber lower mounting bolt lose on my 2013 BH390 when I bought it too. Took it to Freightliner and they were no help so I crawled underneath and tried to shake anything I could. Found the slightly lose bolt, tightened it up and all is good now.
cansosd is offline   Reply With Quote
Old 10-14-2014, 12:58 PM   #13
klucas's Avatar
Yes mine was the same. Couldn't tell it was loose until I put a wrench on it and got a full turn. I hope you can figure it out. Ken
klucas is offline   Reply With Quote
Old 10-18-2014, 10:29 PM   #14
Joedebrv's Avatar
Shock bolts need to be tightened , common problem from factory
Joedebrv is offline   Reply With Quote
suspension
