Old 05-01-2013, 08:35 PM   #1
Switch in cabinet under mid-section TV
I have a 2008 Berkshire that has a button in the cabinet under the TV in the living room. I cannot figure out what the button/switch does!
There is another switch that is the antenna booster...just in front of that (closer to the cabinet door) is the black switch that can be pressed up or down. Any idea what this is?
trttrving is offline   Reply With Quote
Old 05-01-2013, 09:36 PM   #2
Berkshire 390QS
NO3putt's Avatar
Stero surrond sound speakers.
Old 05-02-2013, 07:51 AM   #3
DanielJ's Avatar
I believe that is the case for my 2008 as well.
2008 Berkshire 390TS
DanielJ is offline   Reply With Quote
Old 05-02-2013, 09:25 AM   #4
tmmar's Avatar
trtt,
I guess you didn't consult the extensive, detailed manual that comes with your coach!!! NOT!
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 05-02-2013, 09:36 AM   #5
I would not have figured that out! Wow. Thanks for the information.
Tmmar, my thoughts exactly! It is a beautiful coach with all the trimmings and the manual is the opposite...with a picture of a 80's coach on the front cover! Oh well...the forum makes up for it!
Thanks, all!
Old 05-05-2013, 07:41 PM   #6
Hallen01's Avatar
Antenna switch
On my 2013 390RB:
Button in (ON), green light ON: For TVs to use antenna broadcast signal (also puts 12VDC to antenna booster/signal strength LEDs above driver's head); must have that local switch ON also.
Switch out (OFF) green light OFF: For TV to use cable signal.
Hallen01 is offline   Reply With Quote
Old 05-05-2013, 09:59 PM   #7
Campin Cajun's Avatar
I found that same switch today. I have no idea what it is for either. I'll do more investigation tomorrow when I have less people here.
Today was friends taking the tour of the new wheels....lol, enjoyable for the first three tours, it got kinda old after #5.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 05-06-2013, 01:13 AM   #8
Himcules's Avatar
also to note, the surround sound only works with the dvd player. satellite tv, over the air, anything else you put connect in does not use the surround sound unless you have an input into the dvd player for audio.
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-07-2013, 08:02 AM   #9
That little black switch controls the speaker or subwoofer? that is below the DVD player.
ID:	29792   Click image for larger version
Old 05-07-2013, 10:57 PM   #10
Himcules's Avatar
that black switch is the power for the subwoofer.
the ceiling speakers are powered by the dvd player.
