Old 11-11-2015, 04:41 PM   #11
I-RV's Avatar
While at a Cummins factory shop, I purchased Valvoline Premium Blue Extreme, Full Synthetic 5W40. It even has a Cummins endorsed seal on it. Cummins highly endorses it, but I'm sure that other brands will do.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 11-12-2015, 10:59 AM   #12
Kenny,
Thanks for sending me to the Cummins manual. I thought I had read it, but I hadn't! It provides similar information to the RAM manual.
Just for the record, my manual is Owners Manual ISB6.7 CM2350 B101. Page V-22 suggests that any revisions are available in Bulletin 3810340. The manual does specify the following oil API gravities as being acceptable:
All Seasons (5F and up): Either 5W40 or 15W40
All Seasons (-5F to 115F) 10W30
Winter Conditions (-5F to 70F) 10W30
Winter Conditions (-10F to 70F) 5W30
Arctic Conditions (32F and below) 0W30
Interestingly, this means that it recommends 10W30 over 5W40 for temperatures that drop to -5F. I had thought that you only had to worry about the low end of the viscosity range for cold temperatures, but they say that is wrong.
Also, it says nothing about 0W40, which is an available synthetic oil.
Page V-21 states that oil must meet Cummins Engineering Standard CES 20081, which is apparently stricter than the American Petroleum Institute API CJ-4/SL.
2015 Berkshire 34QS
2005 Acura EL aka Honda Civic
Gordon Sick, Calgary
2015 Berkshire 34QS
2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 11-12-2015, 11:11 AM   #13
Since Mobil 1 Delvac is a 0W40, it is not strictly within the list of acceptable Cummins SAE weights.
But, two oils are available to us Canadians, that I can see:
Shell Rotella T6, as well as Motomaster Formula 1 Synthetic, 5W-40 are CJ-4 rated and meet Cummins CES 20081
2015 Berkshire 34QS
2015 Berkshire 34QS
Old 11-12-2015, 11:47 AM   #14
Kenny kustom's Avatar
If you are never winter driving it, stick with 15w40.
2015 RAM 3500 CCSB CUMMINS
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 11-12-2015, 12:28 PM   #15
Kenny,
But, if one wants to use synthetic oil, they have to go to 5W40 or 0W40, given the choices I have at Canadian Tire. If I look long enough, I might find a synthetic 15W40 or 10W40 that meets the Cummins CES spec, but I like the discounts at my local store.
2015 Berkshire 34QS
2015 Berkshire 34QS
Old 11-12-2015, 12:33 PM   #16
One more thing from the Cummins ISB6.7 manual.
Page 1-8 talks about fuel dilution of lubricating oil becoming a problem if one operates the engine at low idle for long periods with the engine coolant below 160F. That is not likely a problem that I would have.
The manual goes on to say on page V-22 that "Multivisosity oils rated 0W-30 do not offer the same level of protection against fuel dilution as to higher multigrade oils.
2015 Berkshire 34QS
2015 Berkshire 34QS
Old 11-12-2015, 01:07 PM   #17
The Cummins oil bulletin that I mentioned earlier is available without a login at
http://www.granlydiesel.dk/fileadmin...il_3810340.pdf
2015 Berkshire 34QS
2015 Berkshire 34QS
Old 11-12-2015, 05:15 PM   #18
ervinglobal's Avatar
Originally Posted by gordonsick View Post
I'd like to run synthetic oil in my Cummins ISB 6.7. Cummins says you can use synthetic but it also specifies 15W40 oil. At Canadian Tire I can get synthetic Mobil 1 or Rotella diesel oils that meet the Cummins spec except that they are 5W40 or 0W40. Does anybody know of a Cummins statement on this?
I live in Calgary. I always used 5W40 Amsoil. I had many diesel trucks Ford, GM Cummins I just sold my 2014 6.7l Cummins Dodge Ram. I find this oil is the best for me all year around. You can order it on line and delivered to your house. Now I have a 9.3L Maxxforce in our motor home. I just had the first oil change I feel a difference in sound and performance when it starting in colder climate. You will not be sorry to switch. It cost a little more but so as the mechanic shop if something brake down.
Cheers
ervinglobal is offline   Reply With Quote
Old 11-12-2015, 05:26 PM   #19
Kenny,
2015 Berkshire 34QS
I run the rotella 5w40 year round.
Catch it when it's on sale and stock up.
Filters from genos.
Easy peasy.
2016 Sabre 36QBOK
Old 11-13-2015, 09:54 AM   #20
baddmann's Avatar
I run Rotella T6 in everything. Jeep, Jet Skis, Berk, etc. It is one of the better oils on the market. If you look at other forums, it is debated quite frequently. I think the main issue with oil is changing it during proper intervals.
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
weight
