Old 12-13-2015, 04:47 PM   #1
Go Seahawks!
Subsailor's Avatar
Tail light lens torx size
Hello all, I have a tail light out and when I went to remove the lens to get to it, I ran into a bit of confusion. They sure look like torx head screws, but a 15 was a little too small and a 20 was a little too big. To the best of my knowledge, there isn't a torx between those two. Thoughts?
Glenn and Darcy
2013 Berkshire 390RB
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 12-13-2015, 04:49 PM   #2
accumack's Avatar
Use a square drive.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 12-13-2015, 05:06 PM   #3
Go Seahawks!
Subsailor's Avatar
Originally Posted by accumack View Post
Use a square drive.
Thanks, I'll try that.
Glenn and Darcy
Pacific Northwest
Old 12-13-2015, 06:37 PM   #4
Campin Cajun's Avatar
He's correct, it is a Torx drive but it's an 8 point and not a 6 point. There are several others like this also on the motorhome.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 12-13-2015, 06:58 PM   #5
Kenny kustom's Avatar
Ah yes.
Good ol " triple square"
Welcome to the Germans.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-13-2015, 07:08 PM   #6
Use a square drive.
Correct answer! Youroo!!
Old 12-13-2015, 07:11 PM   #7
Really??
2016 Sabre 36QBOK
I am nice!
Old 12-13-2015, 07:18 PM   #8
tmmar's Avatar
I had the same issue a while back and called the factory and they told me to use a square drive. I tried it and it worked fine. I found that they mix torx, square drive, and phillips head screws in the build.
Tom and Margaret
2014 Berkshire 390bh-60
Old 12-13-2015, 07:25 PM   #9
Are you talking " Robertson" ?
2016 Sabre 36QBOK
I am nice!
Old 12-14-2015, 06:10 AM   #10
It's a #2 Robertson bit
Paul
Paulie Boy is offline   Reply With Quote
light
