Old 02-04-2015, 09:39 AM   #11
Berkshire club
Berkshire Driver's Avatar
Had a problem with ours on our first trip and had to replace the water pump cause it would pulsate causing the heater to not pickup flow and would keep shutting off the heater and after replacement have had no problems to date with the water heater, i did go outside and unstick the exhaust switch in the heater 1 time with a long flat tip screwdriver on that first trip cause i read it would cause a flame off condition. but all good now and much better water pressure too.
2014 360QL-60 Mystic Garnet
Berkshire Driver is offline   Reply With Quote
Old 02-04-2015, 01:09 PM   #12
Apple Valley, CA
we had the same problem with the water temperature varying. I decided there wasn't enough water flow to keep the water heater operating. I turn the shower on set at all the way hot, and adjusted the water temperature at the thermostat. The shower is now perfect, no change in water temperature.
Roger & Norma
2014 Berkshire 400QL 360
RLloyd is offline   Reply With Quote
Old 02-04-2015, 02:31 PM   #13
Big Rig's Avatar
Tankless hot water options
I had the RV500 tankless in my seasonal Alumascape. It was 4 years old when I sold the trailer. I frequent that campground regularly and know that it is still working fine. I hope to put one in my new trailer. I assume the 550 is new and improved.
Big Rig is offline   Reply With Quote
hot water, tank, tankless, water
