Old 11-22-2012, 06:05 PM   #11
62_inrightlane's Avatar
Originally Posted by EJM4 View Post
I called Girard directly this week in regards to my problem. They tried to dismiss the issue as I did not understand how to use the unit. I informed him I do understand the unit and have read countless articles on how the unit in my coach has failed and they no longer install this unit. He then informed me I was incorrect once again. I was getting no where with him. He said I needed to measure the water temps and call back.
I was not satisfied so I called my salesman at LazyDays and ask what I should do. He had their on site Forest River rep phone me for details. He then called Girard and emailed this attachment. My unit would be the old style and need the wiring changed. I am waiting to hear how to proceed with the repair.
Amazing how Girard blew me off and to find out there is a service bulletin for this unit.
See attachment.
I received the attachment in the mail from Girard along with a coupling to install if I wanted to convert ours. I keep it on low and we have plenty of hot water so I never did the conversion.
Marc & Jan
Molly, Abby & Katie | The Cocker K-9 Kids!|Toad 2014 Cadillac SRX
2012 Berkshire 360FWS, Brake Buddy Vantage|Wineguard Travler SK-3005
62_inrightlane is offline   Reply With Quote
Old 11-22-2012, 08:54 PM   #12
EJM4's Avatar
Not sure where you live, but when the water you are heating is cold - you may not have hot water.
I installed a jumper wire at the magnet and now the Auto / Low switch operates as a High / Low switch like the new versions except the new ones have a dial adjust the temp.
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 11-25-2012, 09:39 AM   #13
Future Berkshire Owner
Joker's Avatar
With very cold water from the hookup, I have had the best luck with shutting off the cold water valve that controls the shower supply. This is in the wet bay. Once that valve is closed, only water which passes through the heater will go to the shower. Otherwise, the shower mixer valve will probably let some unheated water into the shower head. If that water is 40 degrees, you'll notice it!!
As a corollary, if I have that valve closed in Florida, where the water coming out of the tap is already about 80, I practically burn myself in the shower!!
Yes, the overall system is more difficult to manage, but I get to take hot showers for as long as I want!
Joker is offline   Reply With Quote
Old 11-25-2012, 08:11 PM   #14
redneckmf's Avatar
hot water problem
I just purchased a 2013 Berkshire 390 RB, took it out for the first time this weekend and could barely get warm water for a short period of time. It has the Girard tankless with the dial control switch, but the flame does not change at all switching it from low to high. Has anyone had this problem? Thanks
redneckmf is offline   Reply With Quote
Old 11-25-2012, 08:20 PM   #15
EJM4's Avatar
What part of the country do you live in? Was the incoming water warm or cold. If you are in the Northeast where the water is cold this time of year, you will want to have have it high.
Did you try regulating the water flow with only the warm water and not using any cold water?
Earl
Old 11-25-2012, 08:56 PM   #16
redneckmf's Avatar
We live in South Jersey, but we were in Ocean City Md. this weekend... Yes we tried using only the hot water and even turned it down to a very low flow and could barely get enought warm water to wash dishes. Didn't even think about trying the shower! Had the control dial on max, no help. Isn't the flame supposed to increase when changing from low to high? Had no differance in size of flame.
Old 11-26-2012, 06:04 AM   #17
EJM4's Avatar
Redneckmf -
Sent you a PM with a phone number to help you out.
Earl
Old 11-26-2012, 03:58 PM   #18
Earl, I must be one of the lucky ones. I have hot water when it's 38 in Michigan during the spring and hot water when it's 95 in Georgia.
Marc & Jan
Old 11-26-2012, 09:43 PM   #19
redneckmf's Avatar
Thanks Earl, I gave him a call today,but he's out of the office til Dec. 3. I'll try again then. Really appreciate your help. Nels
Old 03-10-2013, 06:40 PM   #20
EJM4's Avatar
Back to square one again...
I thought ours was fixed. We last used the coach in SC during Thanksgiving with no issues. Stuck it in the storage building for a couple of months. Made a run to Western Ohio this weekend. Used the fresh water tank and the water was cold! Could barely get warm water at best!
There has to be a better system. Frustrated!
Earl
