Old 05-01-2016, 11:11 AM   #1
billygo3251's Avatar
Temperature Gauge
Driving home today my temperature gauge mover over to three quarter side which showed it was running hot. I pulled over, tapped on the gauge then it returned to normal, has me perplexed. Anyone else experience this before?
billygo3251 is offline   Reply With Quote
Old 05-01-2016, 12:24 PM   #2
tmmar's Avatar
Billy,
Need a little more info. Year and model Berkshire, travelling on level road or on mountains/hilly roads. Have you checked your coolant level?
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-01-2016, 12:28 PM   #3
2011 36, driving on I95, water pump replaced 4 months ago, coolant is fine. Gauge went back to normal after I stopped and tapped gauge.
Old 05-01-2016, 01:39 PM   #4
tmmar's Avatar
Did you do any further driving after tapping on the gauge and if so, did the temp stay in the normal range? If so, sounds like a glitch with the gauge. My gauge fluctuates up slightly and then back to normal while driving.
Tom and Margaret
Old 05-01-2016, 02:51 PM   #5
After tapping the gauge, drove about 20 miles, the gauge returned to its normal place.
Old 05-01-2016, 05:19 PM   #6
NV245's Avatar
When I'm in doubt, I use the Freightliner display for actual temperature, I also use it for tranny temp. The display will also give an overheat warning as well as a chime warning.
NV245 is offline   Reply With Quote
Old 05-01-2016, 06:38 PM   #7
hordok's Avatar
That's a great idea. Thanks
2016 Charleston BH
2017 Jeep Wrangler Rubicon - purple - toad
hordok is offline   Reply With Quote
Old 05-04-2016, 05:50 AM   #8
kingwood390bh's Avatar
If you see temperature rise again, stop, go behind the coach and feel if fan is moving a lot of air and blowing it out the back. My fan clutch failed over a 3 month period. It led to several temperature spikes and finally had to be replaced.
kingwood390bh is offline   Reply With Quote
Old 05-04-2016, 10:48 AM   #9
ernest917's Avatar
NV245...
I didn't know that about the Freightliner display.... That's good info.... Thanks....
ernest917 is offline   Reply With Quote
Old 05-04-2016, 12:25 PM   #10
mikeborny's Avatar
At what temps on the engine and transmission would the warning light and sound activate?
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 05-04-2016, 01:15 PM   #11
NV245's Avatar
I haven't had a trans temp warning, but I think the coolant warning came on at 220 degrees Fahrenheit.
Old 05-04-2016, 02:06 PM   #12
mikeborny's Avatar
What driving conditions triggered the high engine temp warning? I am heading to west coast next month and will be doing alot of mountain driving from Southern California to Seattle and thru cascades.
Old 05-04-2016, 02:51 PM   #13
accumack's Avatar
My wife and I have traveled all over the west crossing the continental divide numerous times in a day and never came close to overheating. You'll be fine.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 05-04-2016, 03:12 PM   #14
Master of his Domain
I second the failing fan clutch issue. I had intermittent high temps that would vanish after a stop and not recur for many miles. Usually, the coach would sit for a while, then the fan would present as an issue, only to disappear after a roadside break.
The fan eventually seized and took the serpentine belt out with it. Both were covered under an extended warranty I bought in 2014 with my pre-owned 2009 Berk BH. The total cost for the fan repair was about $2,000.
Moose
2009 FR Berkshire 390BH
jbramhall is offline   Reply With Quote
Old 05-04-2016, 03:57 PM   #15
NV245's Avatar
I was in a hurry to get home, had cruise set at 68 (normally run 63), Jeep Grand Cherokee in tow, and started pulling Pennsylvania mountain on a 90 degree day. I didn't watch the gauge and as I approached the top of the hill, I got the warning, backed off and the warning quickly disappeared.
