05-01-2016, 11:11 AM
Temperature Gauge
Driving home today my temperature gauge mover over to three quarter side which showed it was running hot. I pulled over, tapped on the gauge then it returned to normal, has me perplexed. Anyone else experience this before?
05-01-2016, 12:24 PM
Billy,
Need a little more info. Year and model Berkshire, travelling on level road or on mountains/hilly roads. Have you checked your coolant level?
Tom and Margaret
2014 Berkshire 390bh-60
05-01-2016, 12:28 PM
2011 36, driving on I95, water pump replaced 4 months ago, coolant is fine. Gauge went back to normal after I stopped and tapped gauge.
05-01-2016, 01:39 PM
Did you do any further driving after tapping on the gauge and if so, did the temp stay in the normal range? If so, sounds like a glitch with the gauge. My gauge fluctuates up slightly and then back to normal while driving.
Tom and Margaret
05-01-2016, 02:51 PM
After tapping the gauge, drove about 20 miles, the gauge returned to its normal place.
05-01-2016, 05:19 PM
When I'm in doubt, I use the Freightliner display for actual temperature, I also use it for tranny temp. The display will also give an overheat warning as well as a chime warning.
05-01-2016, 06:38 PM
That's a great idea. Thanks
2016 Charleston BH
2017 Jeep Wrangler Rubicon - purple - toad
05-04-2016, 05:50 AM
If you see temperature rise again, stop, go behind the coach and feel if fan is moving a lot of air and blowing it out the back. My fan clutch failed over a 3 month period. It led to several temperature spikes and finally had to be replaced.
05-04-2016, 10:48 AM
NV245...
I didn't know that about the Freightliner display.... That's good info.... Thanks....
05-04-2016, 12:25 PM
At what temps on the engine and transmission would the warning light and sound activate?
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
05-04-2016, 01:15 PM
I haven't had a trans temp warning, but I think the coolant warning came on at 220 degrees Fahrenheit.
05-04-2016, 02:06 PM
What driving conditions triggered the high engine temp warning? I am heading to west coast next month and will be doing alot of mountain driving from Southern California to Seattle and thru cascades.
05-04-2016, 02:51 PM
My wife and I have traveled all over the west crossing the continental divide numerous times in a day and never came close to overheating. You'll be fine.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
05-04-2016, 03:12 PM
Master of his Domain
I second the failing fan clutch issue. I had intermittent high temps that would vanish after a stop and not recur for many miles. Usually, the coach would sit for a while, then the fan would present as an issue, only to disappear after a roadside break.
The fan eventually seized and took the serpentine belt out with it. Both were covered under an extended warranty I bought in 2014 with my pre-owned 2009 Berk BH. The total cost for the fan repair was about $2,000.
Moose
2009 FR Berkshire 390BH
05-04-2016, 03:57 PM
I was in a hurry to get home, had cruise set at 68 (normally run 63), Jeep Grand Cherokee in tow, and started pulling Pennsylvania mountain on a 90 degree day. I didn't watch the gauge and as I approached the top of the hill, I got the warning, backed off and the warning quickly disappeared.
