Old 03-31-2015, 07:00 AM   #21
gasman94's Avatar
Originally Posted by outloud View Post
If I may isn't easy to just look at the gauge to see how low it is. I think it's a 13 gallon tank, and as far as fill up use the pump. DEF in all my stops are in the truck lane anyway you have a fuel door on both sides so use the side that the DEF tank.��
Sorry, you're right....13 gallon tank. There is an indicator light (series of progressive lights) on the inside and a gauge on the tank itself. And yes, there are fuel doors on both side, but in order to fill on the same side as the DEF at most stations, you must go into the pump areas backwards. This generally will work at a large facility when it's not busy, but you don't want to do that with lanes full of truckers waiting to fuel. I'm not so sure that many of them really like us there anyway.....
Rich
gasman94 is offline   Reply With Quote
Old 03-31-2015, 07:20 AM   #22
I-RV's Avatar
Originally Posted by jcowles3 View Post
Thanks for the solution . Got my pump and a 5 gal container, should help me not get laughed at by others!
Just a suggestion; 5 gal. container takes up a lot of valuable cargo space. From Walmart, I got two, 2.5 gal. blue containers with spout. They fit perfectly on the top shelf of the rear passenger storage compartment. I installed a bungee across to keep them secure.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 03-31-2015, 02:30 PM   #23
baddmann's Avatar
I tried the 5 gallon tank with a funnel/pump and somehow managed to get it everywhere. Even though the 2.5 gallons cost more, I can get them started and them shove them up over the coach tank and let them drain while I pump fuel. Also, I have to go in, prepay for fuel, pump it, then go back in and prepay for DEF. It just doesn't seem worth the hassle to get DEF at the pump.
BTW, Best price I have found is $10.99 at Sam's
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
Old 03-31-2015, 04:39 PM   #24
dbarr's Avatar
Back in the days before satellite diesel pumps were a common convenience for us truckers we would occasionally have to toss the fuel nozzle under the tractor to reach the other side. Will the DEF hose not reach to the other side going under the coach. I've never had to pull more than a couple feet out to reach my tank (so i don't know)but have noticed other makes of trucks that have the DEF on the right side. I can't imagine them going to all the trouble that you all are.
And, we don't mind, like we would've years ago, that you use the same facilities as truck stops are much more plentiful these days and the sitting in line 2 and 3 deep to get fuel don't happen much anymore but, do be quick if someone is waiting and always pull forward before going inside.
Sent from space
'15 F150 Ecoboost Maxtow Scab '13 Freedom Exp. 233RBS
Days camped 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....52
dbarr is online now   Reply With Quote
Old 04-01-2015, 07:26 AM   #25
I-RV's Avatar
Baddman, I do not understand "shove them over the coach tank? or what you are doing. At a truck stop there is no problem pumping diesel and DEF with one payment; its just the bad location where the MH DEF fill is.
I have been paying $2.79 for DEF at the pump. I used my own 2.5 gallon containers. Most of the time, I merely place the just filled 2.5 gallon container in the cargo compartment and then fill the DEF at my leisure, between fuel fill-ups.
Old 04-01-2015, 07:42 AM   #26
baddmann's Avatar
The small containers from Peak are flexible if you take it out of the box. I take it out, get it started and after 1/4 or so I compress the container and squeeze on top of the coach RV DEF tank. It will drain slowly while I am getting fuel.
I have only gotten DEF at the pump a few times, but I have never been able to get both at the same time.
Brian and Kelly
Old 04-01-2015, 08:11 AM   #27
I-RV's Avatar
Baddmann, can you reuse and refill the containers - just a suggestion. At for example, a Flying-J truck pump, you must select on the screen that you want DEF before you pump diesel. After hanging up the diesel nozzle, you need to depress the big DEF button; then the DEF nozzle will be active. You will have one bill with both diesel and DEF.
I we had the DEF tank on the drivers side, we would just pull forward a bit and then fill the DEF. However, if you pull into the lane backwards, you can do that, because we have fuel ports on both sides. As stated earlier, I go in the forward way, fill with diesel, then fill my 2.5 gal container, stick it in the cargo compartment and fill the DEF later. I used to carry two 2.5 gal containers, But I found that if I keep up with the DEF constantly filled, it worked fine - not a bad trade off, considering.
Old 04-01-2015, 08:58 PM   #28
edgewant's Avatar
Most of my trips are 300 miles or less so I carry a 5 gal container of DEF that is generally full. I usually fill it at a Pilot or Flying J. I carry it with me in my truck when we're not in the motorhome camping and fill it when it's convenient. I then top off the MH def tank. Use a smaller 1 gal container to make the transfer. Works out pretty good.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 04-02-2015, 06:37 AM   #29
15berkxl's Avatar
Does the RV lanes at Flying J or Pilot have DEF pumps. That way we won't upset the 18 wheelers. Also in the back word state of Indiana non DOT rigs are not allowed in truck lanes.
Wayne
15berkxl is offline   Reply With Quote
Old 04-02-2015, 07:37 AM   #30
I must be breaking all the rules. I have always used the truck lanes in Ind. No one has ever suggested that I shouldn't.
