Old 03-28-2015, 08:03 AM   #1
I-RV's Avatar
The DEF Filling Bugaboo !!!
The DEF tank is not only on the wrong side, but having the door open upward instead of sideways, it is difficult to get a jug in to pour. I have been using a funnel with a hose and two people to do the job. I also have resorted to pulling into diesel lanes the opposite way
After three years of wrestling with this, I have an idea on how to make the job easier. I was thinking of installing a small $20 self priming diaphragm pump (5 L/min) in the hydraulic compartment. 12V power is there, which is great. I was planning on a momentary switch to control. Again, the doors opening upward would mean that if the hydraulic pump door was open, one would have to stoop below it. To alleviate this, I was planning on extra length tubes and a switch on a line so that the hydraulic compartment door could be lowered, but not completely closed. Another thought is to install a water resistant box in the DEF tank compartment to house the pump (little more difficult).
Has anyone done something similar, have suggestions, or even a better idea?
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 03-28-2015, 10:57 AM   #2
I'm with you... Not sure why they did this... I'll like to switch a battery component with the def tank. Or a transfer or fill pipe from the proper side.
Jc
2014 400BH-60
jcowles3 is offline   Reply With Quote
Old 03-28-2015, 11:56 AM   #3
2014 360 QL
po 185's Avatar
I use a transfer pump , you can get it on amazon
sierra jb5684 battery operated transfer pump
works great and I pump it right out of the DEF jugs that it comes in
2014 360 ql
po 185 is offline   Reply With Quote
Old 03-28-2015, 01:05 PM   #4
gspencer4's Avatar
I'll take some pictures, but I went totally "manual"
1. I bought a shower suction cup to hold a wide mouthed funnel
2. I bought plastic tubing to extend down to the DEF tank
3. Pour DEF into the funnel and fill up the tank - one man operation <$15
Pictures to follow.
Greg Spencer
2014 Berkshire 390BH-60
"Scout"
Greg Spencer
"Scout"
Toad: 2014 Subaru WRX
gspencer4 is offline   Reply With Quote
Old 03-28-2015, 02:51 PM   #5
gspencer4's Avatar
Here are my pictures:
Name:	ImageUploadedByForest River Forums1427572024.683065.jpg
ID:	72372Click image for larger version
Name:	ImageUploadedByForest River Forums1427572039.788069.jpg
ID:	72373Click image for larger version
Name:	ImageUploadedByForest River Forums1427572058.900946.jpg
To the best of my memory, I got the suction cup from Bed Bath & Beyond, the funnel from NAPA or Advance Auto, and the tubing from Ace H/W
Greg Spencer
"Scout"
Greg Spencer
"Scout"
Old 03-28-2015, 03:13 PM   #6
dan-nickie's Avatar
Simply functional solution.
Thanks.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-28-2015, 04:47 PM   #7
Campin Cajun's Avatar
Very nice Greg. A good simple solution.
For times when I am at a fuel stop that has DEF pumps. I just pull forward and use the DEF pump that faces away from my PS. The hose is long enough so I can pull it around to my coach and fill the tank.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 03-28-2015, 06:10 PM   #8
I STILL prefer to go thru the lanes backwards. Really torques off many of the 18 wheeler guys!!! Love doing that since I used to be one of THEM!!!
Seriously, some of these ideas are pretty well thought out. Except for the lower price of going thru the lane backwards, I'd probably do one of them.
Longer "door raisers" would be a REAL improvement, even for us renegades!!
Boowho??
boowho is offline   Reply With Quote
Old 03-28-2015, 06:27 PM   #9
tmmar's Avatar
I found that the truckers are really nice and don't really have an issue with my going in the 'wrong way' when I tell them that is what I need to do to fill my DEF.
Tom and Margaret
2014 Berkshire 390bh-60
Old 03-28-2015, 07:08 PM   #10
I-RV's Avatar
When I go in backwards, I first go in forward to one of the outer lanes. I stop as normal, just opposite them diesel pump and then go outside with several orange cones. I place them about 10 ft beyond the toad. I do this so that A 18 wheeler doesn't pull in behind. I then drive out and make the 180 where ever I can. Then pull in backwards at my reserved spot. Fill diesel, then pull further in to fill DEF. Orange cones are still out there to keep 18 wheelers from thinking there is an open
PO 185 uses a battery operated pump which he says works great. I might consider this over my idea of a built-in pump. Lot of good ideas here.
