Old 07-29-2019, 12:28 PM   #1
ernest917's Avatar
The Hits Keep Coming
Nothing like a blow out at 60+ mph on a rear tire on tow car to ruin a perfectly good day (and take 3.5 hrs to resolve)
Especially when your *#*#* tire monitoring system doesnít acknowledge that anything has happened!!!!! (Thank goodness for a kind soul following me that let me know....)
The second picture shows the other rear tire - was about to have same thing happen there..... Obviously, thereís an issue that needs to be addressed here - alinement issue ???? Appointment set for Wednesday AM....
Also - just to show that the good Lord DOES watch over you - issue occurred 14 miles from a Walmart .... plus they even had two tires in stock.... Thank You Lord!!!
ernest917 is offline   Reply With Quote
Old 07-29-2019, 12:35 PM   #2
wmtire's Avatar
Dang Ernest, that's just plain ugly. What kind of tpms system was it that shows up in the motorhome for the toad?
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 07-29-2019, 12:38 PM   #3
Tell us a little more about the toad... 4 wheels down?... tow dolly?
Have you towed this vehicle a lot?
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 07-29-2019, 12:41 PM   #4
CZNEDY's Avatar
YIKES! Glad you made it back onto the road. That other tire doesn't look good. What the heck happened to it?
2018 BERKSHIRE 34 QS
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 07-29-2019, 12:46 PM   #5
Broken Toe
Cowracer's Avatar
Originally Posted by ernest917 View Post
Attachment 211045
Attachment 211046
Looks like the rear axle of the toad has some camber in it. Only think I can think of to wear the edge out like that. You might want that checked out.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Snowball" 2017 Ram 2500 Laramie Diesel
ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 07-29-2019, 01:01 PM   #6
Looks like an alignment issue causing the inside edges to wear out.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 07-29-2019, 01:32 PM   #7
Iwannacamp's Avatar
Tim
MMHMMM serious wear issues
2017 Puma 297RLSS
Old 07-29-2019, 02:20 PM   #8
Berkshire 390QS
NO3putt's Avatar
Do you have a repeater for the TPMS? Found out ours didn't pick up the toad very well without it? Skip
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
Old 07-29-2019, 02:32 PM   #9
Semperfi24's Avatar
I agree with this thought. I recently read from TireMinder that they used to provide the signal booster as an "optional" part that only some would need (for extreme distances between the driver and the wheels furthest back). But, in recent years with all of the increases in BluTooth use, they now changed their recommendation to every TPMS install to use the signal booster because of signal interference.
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 07-29-2019, 09:05 PM   #10
ernest917's Avatar
I do have a signal booster and system has worked great for years - monitors coach and toad....
It was showing temp/pressure on all tires (because I use it to check ALL tires before I hit the road every morning) BUT failed miserably to notify me when tire blew..... Should gave beeped of flashed red or something..... If not, itís a total waste of time/money....
Itís a Tire Minder system..... Used it for years.....
