Old 05-02-2014, 06:39 PM   #1
Thermostat Gremlins
This morning I switched on my heat pump. It came on, but after a few minutes it automatically cut out and the furnace cut in. It switched back and forth 2 or 3 times all by itself.
The display was flipping between HP and FURN about once per second.
Anyone else had this happen??
Boowho??
boowho is offline   Reply With Quote
Old 05-02-2014, 06:52 PM   #2
tmmar's Avatar
Bill,
I have not had this happen to me.
Did you try doing a reset on the thermostat? Here's the procedure.
Make sure the thermostat is in the OFF condition.
Simultaneously press and hold the MODE and ZONE buttons.
The LCD should display “IniT” and all available zones.
Release the MODE and ZONE buttons.
Press the ON/OFF button to exit system set up.
The furnace ON/OFF temperature differential should be set at this time.
Might want to give this a try.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-02-2014, 06:59 PM   #3
Originally Posted by tmmar View Post
Bill,
Tom
Thanks Tom.... I WILL give it a try.
Boowho??
Old 05-03-2014, 11:04 AM   #4
gasman94's Avatar
Are you guys getting both a/c units to use the heat pump?
Rich
gasman94 is offline   Reply With Quote
Old 05-03-2014, 11:11 AM   #5
tmmar's Avatar
Rich,
Only one of my a/c's is a heat pump the other is a/c only.
Tom
Tom and Margaret
Old 05-03-2014, 11:41 AM   #6
gasman94's Avatar
Rich,
Tom
Thanks Tom. I thought that I read on a previous post some time ago that there was a way to turn on the heat pump to the a/c unit in the bedroom. Both units appear to be the same. They also told me at the factory that only one is operable.
Old 05-03-2014, 02:19 PM   #7
Berkshire 390QS
NO3putt's Avatar
Both of mine are ac and heat pump.
Old 05-03-2014, 02:50 PM   #8
tmmar's Avatar
Rich,
If you remove the grill that holds the a/c filter, if you look around you can see the model number. If you look that model number up it you should be able to see if it has heat pump ability. If it does, you would need to go up on the roof and remove the shroud. There is an aluminum covered box on the passenger side. Remove the cover and you will see a circuit board. There is a series of dip switches on the board. You need to set to the dip switch marked 'heat pump' to the 'on' position to enable the heat pump. After that is done, you would need to reboot the thermostat as I described above to recognize the units new settings.
Good luck,
Tom
Tom and Margaret
Old 05-03-2014, 04:03 PM   #9
gasman94's Avatar
Thanks Tom. I also have a '14, so I probably have the same setup. I will check, however.
Old 05-03-2014, 07:39 PM   #10
Todouble's Avatar
How cold is it outside? Heat pumps are only good in these RV prob down to 35ish. It may work off an outdoor air temp sensor and below a set point auto switch to gas furnace. Just a thought. Or this could be the case and you have a faulty sensor thinking it's lower than it is and trying to switch to propane
Todouble is offline   Reply With Quote
thermostat
