Old 01-15-2011, 11:32 AM   #1
amarzano's Avatar
Thermostat in Bathroom
Here is what I learned this morning..
The fantastic fan in the bathroom is controlled by the thermostat in the bathroom. If the temp is set too high - the fan will not run. Not sure what the logic is - but did wonder what that thermostat controlled.
I now just turned it all the way down.
Camping this weekend..
2011 Berkshire 390BH-60
Cummins ISB 360hp/800ft-lbs DEF
Allison 3000
amarzano is offline   Reply With Quote
Old 01-16-2011, 10:11 AM   #2
That is an intereating bit of information as I have had intermitent problems with my bath fan. I will be checking to see if adjusting the T-stat will solve my intermittent problen.
Grid_Control is offline   Reply With Quote
Old 01-16-2011, 08:43 PM   #3
2011 Berkshire 390bh
wnytaxman's Avatar
If memory serves me correctly the Fantastic Fan in the bath does not have a power opening switch. You may want to make sure that you have the fan open before you switch the thermostat to activate the fan.
wnytaxman is offline   Reply With Quote
Old 01-16-2011, 09:16 PM   #4
I don't have one, never been near one, but aren't they mainly used to help cool the trailer? Therefore they would act like air conditioning, coming on when the temp rises, and shutting off when the temp cools. Just a guess.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 01-16-2011, 11:15 PM   #5
amarzano's Avatar
No worries there, the fans cover needs to be in the up position to turn on. The thermostat seems to power the circuit.
Allison 3000
Old 01-17-2011, 06:19 AM   #6
CLASS "A" Senior Member
cfsoistman's Avatar
That's how our 2 operate. 1 in the kitchen arae and 1 in the rear bath. They operate if the temps get above the pre determined setting. They have 3 speeds and only operate if the top is open.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-17-2011, 08:07 AM   #7
wnytaxman's Avatar
The one in the bath is also handy when there may be a less than pleasant aura about the bathroom. Also it helps to take the steam out after a shower. We do use both fans to cool the coach and they do work like a charm.
