Old 03-03-2015, 05:59 AM   #1
CAT-RN's Avatar
Thermostat on Berkshire.
I have a 2014 Berkshire 390 FL
With front & rear furnaces.
My back furnace wants to cycle on & off in short sessions.
Both furnaces are controlled by the same thermostat. (Zone 1 & 2)
My question is as to where the actual thermostat is for the two furnaces?
The controller is on the wall in the kitchen just before the hall going into the bath area.
Furnace 1 controls the kitchen forward. Furnace 2 controls the bath and bed area.
Russell
CAT-RN is offline   Reply With Quote
Old 03-03-2015, 06:31 AM   #2
dan-nickie's Avatar
I think you are asking where the bedroom 'temperature sensor' is?
My 2014 RB has it on the wall in the bedroom.
Small black plastic maybe 1 1/2 inches.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-03-2015, 06:43 AM   #3
CAT-RN's Avatar
Ok. Sets up 3/4 high on the front wall of the bedroom?? If that is it mine is white & looks like a plastic vent of some sort. 1 1/4 round ??
Russell
Old 03-03-2015, 06:53 AM   #4
CAT-RN's Avatar
Russell
So Dan is this what you think is the sensor ?
RussellClick image for larger version
Name:	ImageUploadedByForest River Forums1425387215.474210.jpg
Old 03-03-2015, 07:29 AM   #5
dan-nickie's Avatar
RussellAttachment 70587
Yes, that is what I have read on another thread someplace here on FRF.
Wait a minute, that may have been the Smoke Detector.
Now I'm not sure
Dan
Old 03-03-2015, 07:38 AM   #6
JTN8's Avatar
The picture shown above is the sensor for zone 2. Mine 14 390BH, the sensor is black and it is about where the door stops when slid open. My zone 2 also cycles more which I think is due to 1. The bedroom is not as tightly insulated as the front and 2. The position of the sensor is right by the slide and window....
Jason
Old 03-03-2015, 07:48 AM   #7
NV245's Avatar
I found that the wall the sensor is on gets airflow from the hvac systems, and heated or cooled air would blow by the sensor from its access hole in the wall. I plugged around the hole and reduced cycle times, and improved comfort.
NV245 is offline   Reply With Quote
Old 03-03-2015, 08:08 AM   #8
Name:	ImageUploadedByForest River Forums1425391653.849613.jpg
This is mine in a 2011 390RB. On the bedroom wall.
Old 03-03-2015, 10:42 AM   #9
CAT-RN's Avatar
Ok. I don't quite understand your fix. Plugged around the hole ?? Can you explain in more detail. Thanks.
Russell
Old 03-03-2015, 01:08 PM   #10
NV245's Avatar
I removed the sensor grille, it is held in place by two screws. The first time I discovered the air blowing by the sensor, we were on the road, so I used crumpled paper towel to temporarily "caulk" the hole, leaving the sensor bulb in the living area, and remounted the grille. This caused a reduction in rear hvac cycling, and a longer rear hvac runtime as the sensor now reads room temperature, not hvac outlet temperature. The paper towel has been replaced with fiberglass similar to the type used for home window and door installation insulation between door and house framing.
berkshire, thermostat
