Old 09-14-2015, 09:19 PM   #11
dan-nickie's Avatar
Mich don't waste no time! He's got the mod fever. :-)
Dan
2014 Berkshire 390RB-60
dan-nickie is online now   Reply With Quote
Old 09-14-2015, 09:24 PM   #12
I was thinking that same thing Dan. What has it been two days. Pace yourself Joe.
Old 09-14-2015, 09:30 PM   #13
Lol, well just figured one way or the other I have to deal with the emptying of the tank situation. I have a clean out for the septic about 40' from where I could park the coach. 50' of 1" hose is a lot more manageable than 50 0f 3". Plus it'll give me another switch to operate .
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 09-18-2015, 01:54 PM   #14
Well started the install this was the easy part. The wiring of it still needs some engineering. Sure would be nice if FR left a provision for some 12V power in that space. Mounted the pump to a piece of azek, and then the azek to the wet bay. Going to go with a double 45* with a short section of hose right to the pump. Bought most of the stuff from Amazon and a run to H.D. Ordered a 45* and a 90* was going to use the 90* but (2) 45*'s will work out better. So had to order another 45*. Oh yeah, I also rolled the fitting on the coach on a 45* angle.
Joe & Lori
Old 09-19-2015, 06:57 PM   #15
Here a picture of the one I installed about 3 years ago. I removed the white wood panel and then trimmed around it with aluminum to support the drain pipe. It works well because the hose can now be stored back behind the water panel and I did not have access to that area before. Click image for larger version
Name:	ImageUploadedByForest River Forums1442706994.783925.jpg
ID:	89256Click image for larger version
Name:	ImageUploadedByForest River Forums1442707022.645973.jpg
csichoice is offline   Reply With Quote
Old 09-19-2015, 07:03 PM   #16
Kenny kustom's Avatar
I understand the concept...
It pumps your poop.
When or why would this be needed?
Not being a smart azz. Just learning.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-19-2015, 07:13 PM   #17
It pumps your poop.
2008 F350 CCSB V10
2016 Sabre 36QBOK
I'm sort of new at this but for me I thought it would just give me the flexibility to pump up hill to empty if I ever had to. I also have a clean out about 50-60' from where I can park at home so that much 1" hose seemed to be way easier to store than the same length in 3" size.
Joe & Lori
Old 09-19-2015, 07:20 PM   #18
Originally Posted by csichoice View Post
Here a picture of the one I installed about 3 years ago. I removed the white wood panel and then trimmed around it with aluminum to support the drain pipe. It works well because the hose can now be stored back behind the water panel and I did not have access to that area before. Attachment 89256Attachment 89259
CSI, not sure if that's the same pump that I'm using but by chance did you take it apart and turn the discharge 180* to come out that way ? Cause I ran into the problem where it was pointing towards the middle of the coach . Tried to see if you could rotate that discharge piece and saw more negatives from people than someone yeah no problem. Which is the reason I mounted mine on the back partition rather than to the floor. Just curious.
Oh here's another question . Where did you get your power from for the pump ?
Joe & Lori
Old 09-19-2015, 10:31 PM   #19
No the pump came that way with the discharge you might want to look into removing the small white panel that is behind your pump. You can use that space for storage for you hose. For the power I just ran my wires straight from the battery with an inline fuse. The only problem I have with the system is I have to go outside to dump I am thinking about putting a second switch in the bathroom to turn on the pump to dump the gray water since I have three female in the family
Old 09-19-2015, 10:37 PM   #20
You might also want to put a ball vale at the end it makes it a lot cleaner for hooch up and disconnect. I will take a picture of what I have because mine will screw into most dump station so you don't have to use the rubber donut.
ford
