Originally Posted by Phil57
I tried calling today to get a schematic but with no luck. I'll check with my dealer tomorrow. I wish they had better info in line. I also wish I knew where the fuse was.
I'd bet that your control board got fried by the lightening. However, it could be the motor itself.
After having mine completely apart, AFAIK, there are no valves on the output side. The pump pulls out the bowl contents almost like a vacuum cleaner. The only valve is a solenoid on the input fresh water side.
In the output hose there are two flapper valves, but they both face the same way and are designed (apparently) to keep "stuff" from coming back up outta the tank into the toilet bowl.
FWIW, the level of water pumped in the stool (both before and after flushing) is controlled by timing; not by a level sensor. I'm usually on about a 40 PSI water source; right now I'm on 60 PSI and I get a lot higher water level in the bowl.
Gonna have to adjust that, as it darn near overflows pushing the #2 button.
Boowho??
