Old 07-18-2016, 09:29 PM   #31
CAT-RN's Avatar
Originally Posted by KennyGolub View Post
Berlin RV Park. Small sites on a hillside.
I saw that park. West of Berlin. We are right in Berlin at scenic. I laid on the air horn when we went by Berlin park. 30 min ago.
Russell
CAT-RN is offline   Reply With Quote
Old 07-18-2016, 09:46 PM   #32
KennyGolub's Avatar
Wife had the tv volume turned up 😊
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Northern Ohio
KennyGolub is offline   Reply With Quote
Old 07-19-2016, 06:14 AM   #33
Originally Posted by tmmar View Post
There is a cabinet below the water heater. Also, drilling the holes would not stop the water from entering the water heater.
Tom I know that I've mentioned this before. I have the same issue. I did put this on my list of problems for them to look at when we are at the rally. Also get water in the lower bay compartment. Is there / should there be a seal behind the water heater cabinet where it slides into the opening?
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 07-19-2016, 07:20 PM   #34
tmmar's Avatar
Joe,
Good question. Don't really know if there should be a seal behind the water heater. I too have it on my Goshen list.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-20-2016, 08:32 AM   #35
I-RV's Avatar
Tom
The heater box should be sealed all around the front edges and would have been sealed from the compartment if it wasn't for the gas line that pokes through the rear panel at the bottom. On the Gen III, there is a gas line connector on the rear panel.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 08-23-2016, 03:17 PM   #36
captnrick3's Avatar
Well, chasing my tail and looking for a more accurate water pressure regulator is not the point. I've had other campers that had simple water heaters that worked. The Girard does not as attested to by numerous posts here and elsewhere. This shouldn't even be an issue.
All I'm saying is that I'm done with Girard. I want to replace it with something that works. Something that I don't have to wrap myself in tin foil, and change my frequency while rubbing the back of my head.
I appreciate all the info given here and I've taken all the steps suggested by others. A water heater shouldn't be that difficult to get working. Hell, even when it does heat, I have to set the temp on a remote dial in a cabinet. Then in the middle of a shower, you get a blast of cold water. It just isn't right.
Sorry, I'll get off the soap box now......
I have seen the long string of posts about the Girard Gen 2. I had one in our Legacy and changed it out myself for a Girard Gen 3. Wow, what a nice unit and the changeout was not bad. We just returned from several months on the road in a wide variety of temperature situations, that heater was great. Just my two cents worth.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
