07-18-2016, 08:22 AM
#21
Those of you who worked with support at Girard
Just looked it up. Scenic RV Park in Millersburg. I think.
Russell
07-18-2016, 08:56 AM
#22
Russell
That would be the one. How did you derive that info from "Mid Ohio" ?
Ken & Laurie
2022 Riverstone Legacy 39RKFB
2022 RAM 3500 Laramie Dually
07-18-2016, 09:11 AM
#23
Psychic!!!!
Russell
07-18-2016, 09:13 AM
#24
It don't get much more mid Ohio Amish than Millersburg
Are you staying at scenic?
Hope to be going by there later today.
Russell
07-18-2016, 09:44 AM
#25
My Gen 2 has been ok. Not great but for the most part, just ok. The problem I am having now is that when it rains, the water heater cabinet itself fills with about a 1/4 inch of water and it won't light until I wipe up the water and dry it out. Not sure how the water gets in but the bottom of the water heater has water in it. Getting to be very annoying when trying to shower and I need to go out and dry out the water heater.
Tom and Margaret
2014 Berkshire 390bh-60
07-18-2016, 10:03 AM
#26
What about seeing what's under it an drilling a 3/8 or smaller hole to let the water out.
Mine has two real small holes in the front corner? Maybe drill them bigger or bend the bottom down a bit so it drain to the front (door side).
Russell
07-18-2016, 12:30 PM
#27
the couple of times i have called i always got a timely response and was very happy with the tech i worked with
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
07-18-2016, 02:15 PM
#28
Russell
Berlin RV Park. Small sites on a hillside.
Ken & Laurie
07-18-2016, 04:24 PM
#29
We got a late start leaving home. We should arrive at Scenic RV park in Millersburg around 9pm
07-18-2016, 07:54 PM
#30
There is a cabinet below the water heater. Also, drilling the holes would not stop the water from entering the water heater.
Tom and Margaret
07-18-2016, 08:29 PM
#31
I saw that park. West of Berlin. We are right in Berlin at scenic. I laid on the air horn when we went by Berlin park. 30 min ago.
Russell
07-18-2016, 08:46 PM
#32
Wife had the tv volume turned up 😊
Ken & Laurie
07-19-2016, 05:14 AM
#33
Tom I know that I've mentioned this before. I have the same issue. I did put this on my list of problems for them to look at when we are at the rally. Also get water in the lower bay compartment. Is there / should there be a seal behind the water heater cabinet where it slides into the opening?
Joe & Lori
2014 Berkshire 390 RB-40
07-19-2016, 06:20 PM
#34
Joe,
Good question. Don't really know if there should be a seal behind the water heater. I too have it on my Goshen list.
Tom
Tom and Margaret
07-20-2016, 07:32 AM
#35
Tom
The heater box should be sealed all around the front edges and would have been sealed from the compartment if it wasn't for the gas line that pokes through the rear panel at the bottom. On the Gen III, there is a gas line connector on the rear panel.
Hank
Gale & Hank- 2012 Berkshire 390BH
08-23-2016, 02:17 PM
#36
Well, chasing my tail and looking for a more accurate water pressure regulator is not the point. I've had other campers that had simple water heaters that worked. The Girard does not as attested to by numerous posts here and elsewhere. This shouldn't even be an issue.
All I'm saying is that I'm done with Girard. I want to replace it with something that works. Something that I don't have to wrap myself in tin foil, and change my frequency while rubbing the back of my head.
I appreciate all the info given here and I've taken all the steps suggested by others. A water heater shouldn't be that difficult to get working. Hell, even when it does heat, I have to set the temp on a remote dial in a cabinet. Then in the middle of a shower, you get a blast of cold water. It just isn't right.
Sorry, I'll get off the soap box now......
I have seen the long string of posts about the Girard Gen 2. I had one in our Legacy and changed it out myself for a Girard Gen 3. Wow, what a nice unit and the changeout was not bad. We just returned from several months on the road in a wide variety of temperature situations, that heater was great. Just my two cents worth.
2015 Legacy 340KP
2012 Wrangler Sport
