Old 01-16-2013, 06:55 PM   #11
410 QS 425 2011 Birkshire
Found replacement tiles at lowes in the special order bin,238768 maple18beige,not a perfect match but then FR tile was not a perfect match either. Back of tile is a perfect match so made by the same company
malewis49 is offline   Reply With Quote
Old 01-18-2013, 09:57 PM   #12
Unique Tile - The Designer's Choice for Tile and Stone
dogsgocamping is offline   Reply With Quote
Old 01-25-2013, 03:57 PM   #13
Got the tile from lowes not a good match the sample was a better match but have been back too see what are my options are
Old 01-26-2013, 05:28 PM   #14
Found out that lowes ordered the wrong colour but the fix the problem and the right tile is on the way 238768 Maple1Brown (SOS)
Old 01-26-2013, 06:51 PM   #15
Future Berkshire Owner
Joker's Avatar
What's the manufacturer? We were thinking of combating the mismatch problem by picking a tile that is a much darker color, then replacing a few extra tiles in a sort of cross pattern. Then we would do the same pattern a few tiles away. That way the mismatch looks intentional. And it adds a bit of interest to the floor. If I could use the same manufacturer, it may help to match the tile heights.
Joker is offline   Reply With Quote
Old 04-15-2013, 12:53 PM   #16
Is the cracked tile a big Berkshire problem or just a minor low incidence situation??
Popcorn man is offline   Reply With Quote
Old 04-15-2013, 03:30 PM   #17
Joker's Avatar
I haven't heard of it much; must be low incidence.
Old 04-15-2013, 03:32 PM   #18
Joker's Avatar
Oh, plus mine came from the factory that way and ours was really a tiny crack, although it was along the length of the tile. It might have even been cracked before it was installed, just not cracked all the way through...but who knows.
Old 04-21-2013, 07:08 PM   #19
If is IS an isolated situation, then I applaud FR. I've laid lots of tile and if FR can keep tiles from cracking on a surface that has to flex a LOT as the coach goes down the road, then they did a GREAT job of engineering/installing that floor.
Boowoh??
boowho is offline   Reply With Quote
Old 04-21-2013, 09:37 PM   #20
They are replacing two that are grooved when the slide was not adjusted correctly. It really is not noticeable. I hope it's not worse with a poorly matched tile.
