Old 01-25-2013, 07:27 PM   #11
fast murray's Avatar
Originally Posted by ernest917 View Post
Rate of 50% or more should ever be used on dual paned windows.... The Sungard has a rate of 54% so guess its out as a possibility...
Usually the % of tint is how much light will pass through. 5% is super dark, so a higher number should be better.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 01-25-2013, 07:45 PM   #12
ernest917's Avatar
Most good tint will have all the specs which will show the three main areas we should be concerned with - Solar Reflect, Solar Absorb and Solar Transmit.... The absorb spec should never be 50% or higher for dual panes....
ernest917 is offline   Reply With Quote
