Old 01-16-2013, 09:49 PM   #1
ernest917's Avatar
Tinting double paned windows
Has anyone tried to tint their double-paned windows??? I understand that that can be an issue if it isn't done correctly.... I want to tint drivers and passengers side windows...
ernest917 is online now   Reply With Quote
Old 01-17-2013, 08:11 AM   #2
We tinted ours and it works great......
Go to a professional tinting company because you are correct regarding the consequences of doing it with the wrong tinting material. It cost about 300.00 to tent all drivers side but it really helps. Havent done the other side yet.
BamaCorner is offline   Reply With Quote
Old 01-17-2013, 08:50 AM   #3
tmmar's Avatar
I read a post (can't remember when or where it was), but the poster said that you shouldn't tint double paned windows because the tinting reflects the heat into the window and it can cause the seal to fail. Just relaying what I read and don't have any experience with tinting so I can't really say wheather this will indeed happen.
Tom and Margaret
2014 Berkshire 390bh-60
Old 01-17-2013, 10:52 AM   #4
I remember that but mine has worked great......
been on for two years without a problem.
Old 01-19-2013, 12:48 PM   #5
In our Province, it is against the law to tint the driver or passanger window. I know this from personal experience
lefaivre is offline   Reply With Quote
Old 01-19-2013, 08:15 PM   #6
3M has just come out with a clear window tint that can be put on driver and passenger windows plus the windshield. Total solar energy rejected is 34%. We went to the Tampa RV show and was told about it. Window tinting film should not be put on double pane windows or windows with thermal pane.
Momma Tac is offline   Reply With Quote
Old 01-20-2013, 11:55 AM   #7
You can tint double pane windows if you .......
use the correct materials. Tinting Double Pane Windows | Tint Industry. We only tinted the large windows behind the driver seat on he drivers side.
Old 01-25-2013, 02:14 PM   #8
ernest917's Avatar
Anyone heard of Sungard Opti-vision 45??? I just talked to a window tinting company abt tinting the front driver/passenger side windows and this is what he uses on double-paned windows.... Assured me it wouldn't cause seals to blow....
Old 01-25-2013, 06:28 PM   #9
ernest917's Avatar
Just read that no film that has a heat absorbation
Old 01-25-2013, 06:30 PM   #10
ernest917's Avatar
Rate of 50% or more should ever be used on dual paned windows.... The Sungard has a rate of 54% so guess its out as a possibility...
