06-19-2018, 12:19 PM
#21
Gordon, the goodyear truck tire dealer is currently working with his rep on the issue. He said no safety issues which is good given my upcoming 3week 4200 mile trip to Glacier/Yellowstone/Tetons!
06-19-2018, 02:56 PM
#22
Mike, keep an eye on it. Once mine started it got worse real fast.
Dan
2014 Berkshire 390RB-60
06-19-2018, 06:27 PM
#23
Mike,
I had the same issue and a dealer said that there was no issue with the tire. The only thing that was done was to swap the front tire with the rivering with one of the tires from the rear -at my expense of course. They also said that once the rivering starts there is nothing that can be done to correct the issue with the tire involved. Nobody offered any 'monetary assistance' with tire replacement.
Good luck and let us know how you make out.
I will be very interested in the outcome.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
06-30-2018, 05:40 PM
#24
Gordon, I have 2015 Berk, how do you drain the water on your front brakes. I have not done that
07-03-2018, 05:08 AM
#25
Draining air tanks of water
Jshgator,
There are three cable loops spread across the front wheel wells. It is easiest to see them if you have the wheels turned right or left. Pull the cables to drain the main tank, front tank and rear tank.
–Gordon
07-06-2018, 09:18 AM
#26
The front tires on my 34QS cupped and made a heavy vibration noise which got worst and with 36k miles on them (Goodyear didn't offer any assistance), I replaced them. The rears are beginning to cup on the outside. I maintain the proper air pressure. What a difference the new tires made. I won't buy Goodyear again...
07-06-2018, 09:23 AM
#27
Hi, what tires did you put on. My Goodyears with 24k on them are cupping, I had it aligned and it was only needing a little adjustment. Here in Orlando the trucking company that aligns Freightliner chassis said the Goodyear tires are horrible
07-06-2018, 09:24 AM
#28
X2
Jc
2014 400BH-60
07-06-2018, 10:28 AM
#29
Same issue here last year.
In less than 30K miles my front tires were worn down to belts on the inside edges for about 1 - 1.5 inch from edges towards the center while the rest of the thread looked totally fine. Did not think about contacting the GY and just replaced them with Falkens at Tredroc in Oak Creek, WI and did an alignment the as well. Paid $804 for both tires installed and alignment. Love the tires, much better and quitter ride than GYs.
While changing the tires I was told that my front bearings are worn out and had FL replace them under warranty.
Alex and Valerie
2014 Berkshire 400BH
07-14-2018, 09:55 AM
#30
Dragonship Captain
Wow...... 30K and bearings worn?
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
