Old 05-25-2016, 05:48 PM   #1
ernest917's Avatar
Tire Pressure
OK - I have Michelins on my coach... What is the recommended cold pressure?? Front and rear....
ernest917 is online now   Reply With Quote
Old 05-25-2016, 06:12 PM   #2
tmmar's Avatar
Ernest,
You would need the weight of your coach at each wheel (preferably). If not, front axle and rear axle weights would suffice. You would then go to Michelins chart to see what pressure they recommend for your weights and tire size. But, as I said, you need to get the weight of your coach.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-25-2016, 06:27 PM   #3
ernest917's Avatar
I know you're correct but I just need a ballpark idea....
Old 05-25-2016, 06:31 PM   #4
tmmar's Avatar
Ernest,
Take a look at this chart.
Tom
Michelin RV Tires | View Michelin RV Tires load and inflation tables for motorhomes and recreational vehicles. | Michelin RV Tires
Tom and Margaret
Old 05-25-2016, 10:02 PM   #5
dan-nickie's Avatar
What size tire?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-25-2016, 10:51 PM   #6
ernest917's Avatar
255/80/22.5 tires.... 100psi all around OR 105 psi up front and 110 psi rear???
Old 05-25-2016, 11:13 PM   #7
ernest917's Avatar
Man that chart confused the heck out of me....
Old 05-26-2016, 06:53 AM   #8
accumack's Avatar
When i had the 255s I ran 110psi all around. With the 275s I run 105 psi we like the handling and stiffer ride.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 05-26-2016, 07:08 AM   #9
RSchleder's Avatar
I'm surprised that you don't have a "sticker" that tells you the recommended tire pressure attached to your coach.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-26-2016, 08:25 AM   #10
tmmar's Avatar
The tire pressure is dependent on the loaded weight of the coach (coach +fuel,water,passengers,food,holding tanks,propane,lawn chairs, etc,etc.). So the more stuff you put in, the heavier it gets and the tire pressure changes accordingly.
Tom and Margaret
pressure, tire
