Old 04-29-2011, 01:56 PM   #1
2011 Berkshire 390bh
wnytaxman's Avatar
Tire Pressure Monitoring System
If you haven't looked at a tire pressure monitoring system, it would probably be a good idea to check one out. We bought the Tire Tracker system from Lawrence RV Accessories Inc and it is well worth the cost. One of the biggest problems you can have on a motorhome is a blowout or a slow leak. Blowouts are not real common, but the slow leaks are. We have already had one slow leak that could have resulted in a very dangerous situation. If you pull a toad, the TPMS system is a must. It tells you tire pressures and temps and warns you when there is a significant variation.
wnytaxman is offline   Reply With Quote
Old 05-03-2011, 07:17 AM   #2
wnytaxman's Avatar
I must admit that I am kind of curious that no one tows a car with a Berkshire? If you have a toad, the tire pressure monitor is a necessity and it is really recommended with just the motorhome. It can sure save a lot of grief when you have a slow leak and you don't realize it. That is exactly what happened to us in Indiana and it almost caused an accident.
Old 05-03-2011, 08:56 AM   #3
tmmar's Avatar
Ed,
Can't really say why most Berkshire owners don't tow but we bought a TPMS system shortly after I picked up my Berkshire. Besides the safety aspect, it makes checking the tire pressure a very simple task.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 06-04-2011, 09:50 AM   #4
what is a good model recommended to purchase for a TPMS without going broke doing it ?
Team Wilhelm is offline   Reply With Quote
Old 06-04-2011, 10:10 AM   #5
tmmar's Avatar
I have the PressurePro TPMS. Have had it for almost 3 years now and it seems to work just fine. It can handle up to 10 tires (6 on the MH and 4 on a towed vehicle).
Tom and Margaret
Old 06-04-2011, 10:24 AM   #6
Thanks TMMAR. What is the cost approx and is it easy to install ?
Old 06-04-2011, 10:32 AM   #7
MtnGuy's Avatar
We also have the Pressure Pro system, but for 16 tires. We figured we might upgrade to a MH in the future...6 tires there, plus 4 on the toad, plus spares if we want to totally monitor everything.
I think our receiving unit was $190, and $50 for each sensor. The sensors just screw onto the valve stem.
I would recommend metal valve stems on your toad (and MH if they don't already have them), as the weight of then sensor could bend the valve stem at speed due to centrifugal force.
Old 06-04-2011, 11:38 AM   #8
tmmar's Avatar
I think that I paid about the same for the setup. Having metal valve stems is a good point and as mtnguy said, just plug in the receiving unit in and screw the sensors on the valve stems. Very easy setup.
Tom and Margaret
Old 06-05-2011, 03:04 AM   #9
Plug It Right
We found the TST tpms system works best for us. Cost effective, love the monitor and shows both temperature and PSI simultaneously. We've been using ours for a year to monitor 12 tires. Diana
2014 Ram Dually Pickup, Tailgate Easylift, Do More Slide Step & AMP side steps
1996/2010 Triple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Big Foot Automatic Leveling System, TST Tire Pressure Monitoring System, Plug It Right Stabilizers.http://www.plugitright.com/5thwheelREDO.html
Dutch & Di is offline   Reply With Quote
Old 06-06-2011, 03:52 PM   #10
wnytaxman's Avatar
The Tire Tracker System was just under $300 for the base unit and six sensors. One of the things I liked about the Tire Tracker is that the sensors are small and don't seem to create leaking issues with the tires. This system also gives you pressure and temp and provides warnings when all is not well.
