Old 08-30-2013, 06:33 PM   #1
Tire upgrade question
Hello,
I have a 2009 Berkshire 390TS. It came stock with 255/80R/22.5 Michelin tires on steel wheels with hubcaps. Would it be OK to upgrade the tires with 275/80R/22.5 Michelin XZA3+
Thanks for any advice...Donn
DandMBerk is offline   Reply With Quote
Old 08-30-2013, 07:28 PM   #2
Iggy's Avatar
Originally Posted by DandMBerk View Post
Hello,
The only question you must find out and answer is that all dually tires must have a specific distance between them. THis question came up in the Georgetown section. If you can maintain the recommended distance between them your ok. I will try and find my document where it siad a specific distance.
2012 Georgetown XL - 378TS 63K + miles
Old 08-30-2013, 08:10 PM   #3
I think the minimum spacing for the XZA3's is 12.2 inches. This must mean center to center. My duels are 13.5 inches center to center.
Old 08-30-2013, 09:26 PM   #4
Yes you can. I have 275/80 on my 2011 RB 390 and no problem. I have the XZE2 tires. You will need to have a Freightliner shop reflash your computer to get the speedometer correct.
Old 09-02-2013, 11:59 AM   #5
I'm considering going to Michelin XZA2 275/70R/22.5 they are very close in size to the original tires (1' wider) but have a higher weight rating. I wouldn't have to have the speedometer re calibrated with these tires.
tire, upgrade
