Old 10-28-2014, 11:02 AM   #11
Southern Roamer's Avatar
Name:	ImageUploadedByForest River Forums1414511968.658869.jpg
My new tire blocks to keep tires of ground and above casual ground water, w/vinyl tiles to keep pressure treatment chemicals away from tire tread, and plywood underneath to keep 2x12 boards from splitting. Thanks for all the suggestions
Southern Roamer is offline   Reply With Quote
Old 10-28-2014, 05:46 PM   #12
Mmnsc's Avatar
I would be careful about using vinyl tiles as vinyl always has some residual plasterizers in it. The plastetzier is what makes vinyl soft and pliable. The plastizer can attack the tires rubber. A better choice would be polyethylene or polypropylene. The polyolifins are known to be much more stable and inert. Water and chemicals do not attack polyolifins. I use polypropylene under my tires. IMHO
Mmnsc is offline   Reply With Quote
Old 10-28-2014, 05:53 PM   #13
Hmmmm! Back to the drawing board
Don't know if I can find that type of tile and whatever I put on the blocks needs to withstand the movement of the tires without tearing or breaking. I guess I could just get 4 large plastic jack pads from CW and find a way to secure them to the blocks.
Old 10-28-2014, 05:59 PM   #14
Mmnsc's Avatar
Go to the dollar store or other shop and buy white plastic cutting boards as they are polyethylene and usually about 1/4 inch thick. Good luck
Old 10-28-2014, 06:00 PM   #15
Tell me more about your polypropylene. What form is it...sheet, tile, block, pad? And where did you obtain it.
Sent from my iPhone using Forest River Forums[/QUOTE]
Old 10-28-2014, 06:02 PM   #16
Thanks. Your input arrived after I had submitted my question. Thanks for your help
Old 10-28-2014, 06:05 PM   #17
Ford Idaho's Avatar
I built two like this, no paint no stain, plain ol'pine.
Old 10-28-2014, 06:08 PM   #18
tmmar's Avatar
I purchased this black runner from Lowes. Easily cut into lengths needed for under the tires.
Shop black runner at Lowes.com: Search Results!
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-28-2014, 06:08 PM   #19
Since mine are on the ground and in the weather it was necessary to use pressure treated lumber here in Florida where we get so much rain. Else I would have to replace them every year.
Old 10-28-2014, 06:13 PM   #20
On a flat surface like a concrete pad a runner is ideal. However, I have concerns about its durability on an elevated block where the tire has to roll onto and off of the block, creating stress on the runner material. JMHO
pressure, tire, tires
