Old 10-16-2014, 12:51 PM   #1
Southern Roamer's Avatar
Tires on pressure treated lumber
Does anyone know if it is detrimental to tire rubber to park long term on pressure treated boards?
Southern Roamer is offline   Reply With Quote
Old 10-16-2014, 01:17 PM   #2
jimdd810's Avatar
I don't see a problem with mine. And it's been parked all summer.
Life is a highway!!!!!
jimdd810 is offline   Reply With Quote
Old 10-16-2014, 01:18 PM   #3
mTn_biKer65's Avatar
If the travel trailer is in my driveway, and it is about 330 days of the year, it's on pressure treated lumber. No obvious issues to the tires (or lumber ) to date. I've had my current trailer over 2 years and I've done the same for the previous 2 trailers as well.
Paul
Nights camped
2007 Shamrock F19 hybrid - 2010 (22 nights), 2011 (24 nights), 2012 (11 nights)
2013 Surveyor Select 235RKS -
2012 (6 nights), 2013 (32 nights), 2014 (26 nights), 2015 (37 nights), 2016 (14 nights)
mTn_biKer65 is offline   Reply With Quote
Old 10-16-2014, 02:13 PM   #4
RKC02's Avatar
I was told at Freightliner class that an impermeable barrier, such as plastic or good coat of paint, should be on the boards to prevent wicking of oil/compounds from the tires. Same applies to dirt, concrete and asphalt. Seems reasonable and cheap insurance for the tires.
RKC02
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
Old 10-16-2014, 03:55 PM   #5
Thanks for the responses. I think I will put a heavy coat of paint on the boards
Old 10-16-2014, 05:28 PM   #6
I-RV's Avatar
Suggest that you buy some $0.79 vinyl self sticking tiles at Lowes or Home Depot. Cut them to width of your boards. They may not stick at first, but the weight of the RV will make them stick.
2012 Berkshire 390BH
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 10-16-2014, 06:34 PM   #7
Great idea, thanks
Old 10-16-2014, 07:01 PM   #8
Chillbilly's Avatar
I use cutting boards which you can get at any flea market for about a buck a piece. They are impermeable and can be placed on any surface.
Chillbilly
2013 Rockwood Signature Ultra Lite 8244WS
2015 Ford F250 Quad Cab w/6.2 Engine
Chillbilly is offline   Reply With Quote
Old 10-16-2014, 07:21 PM   #9
Boss Hoss's Avatar
I use my plastic leveling blocks.Works well.
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 10-16-2014, 09:21 PM   #10
All good ideas. Thanks to all
Old 10-28-2014, 11:02 AM   #11
Name:	ImageUploadedByForest River Forums1414511968.658869.jpg
My new tire blocks to keep tires of ground and above casual ground water, w/vinyl tiles to keep pressure treatment chemicals away from tire tread, and plywood underneath to keep 2x12 boards from splitting. Thanks for all the suggestions
Old 10-28-2014, 05:46 PM   #12
Mmnsc's Avatar
I would be careful about using vinyl tiles as vinyl always has some residual plasterizers in it. The plastetzier is what makes vinyl soft and pliable. The plastizer can attack the tires rubber. A better choice would be polyethylene or polypropylene. The polyolifins are known to be much more stable and inert. Water and chemicals do not attack polyolifins. I use polypropylene under my tires. IMHO
Mmnsc is offline   Reply With Quote
Old 10-28-2014, 05:53 PM   #13
Hmmmm! Back to the drawing board
Don't know if I can find that type of tile and whatever I put on the blocks needs to withstand the movement of the tires without tearing or breaking. I guess I could just get 4 large plastic jack pads from CW and find a way to secure them to the blocks.
Old 10-28-2014, 05:59 PM   #14
Mmnsc's Avatar
Go to the dollar store or other shop and buy white plastic cutting boards as they are polyethylene and usually about 1/4 inch thick. Good luck
Old 10-28-2014, 06:00 PM   #15
Tell me more about your polypropylene. What form is it...sheet, tile, block, pad? And where did you obtain it.
Sent from my iPhone using Forest River Forums[/QUOTE]
Old 10-28-2014, 06:02 PM   #16
Thanks. Your input arrived after I had submitted my question. Thanks for your help
Old 10-28-2014, 06:05 PM   #17
Ford Idaho's Avatar
I built two like this, no paint no stain, plain ol'pine.
Old 10-28-2014, 06:08 PM   #18
tmmar's Avatar
I purchased this black runner from Lowes. Easily cut into lengths needed for under the tires.
Shop black runner at Lowes.com: Search Results!
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-28-2014, 06:08 PM   #19
Since mine are on the ground and in the weather it was necessary to use pressure treated lumber here in Florida where we get so much rain. Else I would have to replace them every year.
Old 10-28-2014, 06:13 PM   #20
On a flat surface like a concrete pad a runner is ideal. However, I have concerns about its durability on an elevated block where the tire has to roll onto and off of the block, creating stress on the runner material. JMHO
pressure, tire, tires
