Old 05-24-2016, 10:02 AM   #11
15berkxl's Avatar
I have been flat towing Ford sport trac's since 2003. Ford makes a neutral tow switch that disengages the tranny allowing you to tow. F150 is a little larger and heavier but I bet you would still be fine provided you can get the NTS for your model.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 05-24-2016, 10:31 AM   #12
You need to look at your tires on Moho Michelin tires can go 75 but that is the max speed. Look at the tires it saids max speed. I have 275 80r-22. And a Jeep Wrangler there is the procedure for towing and no need to put key in or pull fuses just hook up and tow.
outloud is offline   Reply With Quote
Old 05-24-2016, 10:59 AM   #13
ndfellow's Avatar
Truck it is thx guys!
ndfellow is offline   Reply With Quote
Old 05-24-2016, 11:00 AM   #14
dan-nickie's Avatar
Originally Posted by I-RV View Post
You haven't mentioned which MH that you have, Another consideration is weight. You just do not go by the hitch rating. You need to check whether you will be within the GCWR. Berks with a 2500 MH tranny will be limited to 33,000lb.
Hank
I almost missed it in the OP also. He did say he has the larger engine and transmission which I assume to mean at least a 360 horsepower engine and 2500 transmission.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-24-2016, 11:02 AM   #15
dan-nickie's Avatar
BTW, I could not find a 'cheap' Jeep when I was looking.
Dan
Old 05-24-2016, 11:07 AM   #16
ndfellow's Avatar
Sorry guys yes 360/2500 on MH. Dan cheap jeep is never cheap I also learned in searching. I'm more of a UTV guy and would flat tow my Ranger if it could be and was legal in all states in town. Again appreciate all the feedback
Old 05-24-2016, 11:18 AM   #17
I-RV's Avatar
Typically, the Allison 2500 has come with the 340 engine. The engine is not a problem, but as I stated earlier, the 2500 is rated to pull 33,000lbs. max. Also as many of us has stated in many threads, it is wise to weigh your loaded MH and toad.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 05-24-2016, 11:19 AM   #18
tmmar's Avatar
Just a small correction. If you have the 360hp engine you should have the heavier duty Allison 3000 transmission. The 2500 transmission is in the coaches with the 340hp engine.
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-24-2016, 12:05 PM   #19
dan-nickie's Avatar
Yes I meant to say the 3000 transmission. My bad
Dan
Old 05-24-2016, 01:44 PM   #20
ndfellow's Avatar
Toad vehicle
360/3000 and it's a 2013, wow Brain fart sorry guys. Thx for feedback
toad
