Old 07-17-2014, 10:31 PM   #11
NV245's Avatar
Disconnect battery, walk away for 1/2 hour, reconnect and see if fault returns. Autozone used to read faults for free, could be trans battery disconnected fault. As vehicle battery goes below 9 volts, controllers have no idea what they are doing, especially with key on, so multiple faults can be set, and without complete battery disconnect, these faults will be put into memory until erased. So try battery disconnect for 1/2 hour to allow for capacitors to fully discharge.
NV245 is offline   Reply With Quote
Old 07-17-2014, 11:50 PM   #12
John McClain's Avatar
Ok leaving your auto transmission in park or in N does not effect if the transmission spins or not, The transfer case keeps the transmission from turning . I leave my jeep in park so when my wife jumps in she just has to pull the transfer case back into gear so it wont roll . It's also help to make sure your transfer case is indeed in N . start your jeep up and put the T-case in N now put your auto. transmission in gear R or D if the jeep did not try to move your T-case in N. Turn the engine off 1st back click with the key put the trans in park , Turn the key back till the steering wheel locks up than forward one click the steering wheel should now be unlocked and you should not be abele to turn on the radio. I flat tow my jeep every year to Moab Ut. and the Rubicon trail and have hauled in N and in park . If you PM me I will show you an easy way to wire up your tail lights with no chance back feed to the jeeps electrical system
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 07-18-2014, 09:50 AM   #13
Campin Cajun's Avatar
My Wrangler steering wheel do not lock. Yours shouldn't either Lisa. After putting the transfer case in N and transmission in P you can take the key out. No need to leave the key in the ignition.
2013 Berkshire 390 BH
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 07-18-2014, 12:46 PM   #14
My stearing wheel does lock and being the president of my local jeep club. I sent out a shout on are forums and had about 10 replies so far and all their jeeps steering wheels all lock up to. what year is your jeep ?
Old 07-18-2014, 01:26 PM   #15
Cornelius's Avatar
A correction to my earlier post: It was mid-2008 that Jeep discontinued the steering wheel lock on the Wrangler. If your Wrangler build date was before that, you need a key in the ignition to keep the steering unlocked when towing. The best advice is to follow the owner's manual instructions for your model and year.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 07-18-2014, 03:57 PM   #16
Mine is a 2009 Sahara, no steering lock. I also read that '08 was the year no steering wheel lock was reinstated by Jeep. Sorry Lisa, I just read you have an '07.
Old 07-18-2014, 07:31 PM   #17
LisaBush's Avatar
Thx for all the help. I disconnected the battery for about 30 mins and the light went off.
LisaBush is offline   Reply With Quote
Old 07-18-2014, 07:32 PM   #18
LisaBush's Avatar
Oh, the Jeep is a 2007, it does lock without the key
Old 07-18-2014, 07:53 PM   #19
My 2007 did have the steering wheel lock. I finally took a little time to remove it (it wasn't that hard...just followed a video on YouTube), and it was SOOOO nice not to have to leave the key in to tow!
It seems like a small thing on paper, but it really made a big difference to me!
If you're DIY inclined, you can make that mod to your jeep.
chesterhull is offline   Reply With Quote
Old 07-18-2014, 09:56 PM   #20
You can take your jeep to any dealer and they will remove the lock from the steering wheel. It takes a couple of minutes and is worth the little cost.
