Old 07-16-2016, 06:59 AM   #1
Towing
Trying to decide: Tow dolly or all on the ground. I could sure use some advice..
joet19711 is offline   Reply With Quote
Old 07-16-2016, 07:39 AM   #2
Tow 4 down and never have to be concerned with where to stow the dolly. IMO.
Bunci is offline   Reply With Quote
Old 07-16-2016, 08:50 AM   #3
KennyGolub's Avatar
I had both and prefer 4 down all the way. I did not like getting on the ground to attach the safety chains to the vehicle. Multiply the dislike several times when it's raining.
Ken & Laurie
2015 Berkshire 400QL
2016 Chevy Colorado
Northern Ohio
KennyGolub is online now   Reply With Quote
Old 07-16-2016, 08:58 AM   #4
AREA51's Avatar
When we first started towing 12 years ago we bought a standard shift, front wheel drive Honda Element. Added tow plate and drilled holes in tail light housings to install bulbs similar to a boat trailer, added a 4 pin to 7 pin connector (4 to 6 is also available) and have been happy for all these years. Towed the Honda at least 65,000 miles and no problem. Takes 5 minutes to hook up and 5 minutes to unhook.
GOOD LUCK
AREA51
AREA51 is offline   Reply With Quote
Old 07-16-2016, 09:51 AM   #5
Berkshire 390QS
NO3putt's Avatar
4 wheels down is our perfered method, 45,000 miles no issues just make sure you have a TPMS for the toad.
2015: 188 days, 2016: 72 days,
Skip
Old 07-16-2016, 10:32 AM   #6
Used a dolly for 2 years the wheat 4 down and will never look back. Good luck!
Jc
2014 400BH-60
jcowles3 is offline   Reply With Quote
Old 07-16-2016, 04:17 PM   #7
waiter21's Avatar
IMHO - If I don't use the car while traveling, but am towing the the car mainly so I'll have it at my destination, then dolly may be a better option.
If I like to use the car every night, at every stop, then flat tow would be the better option.
Dolly tow
Advantage - Lower cost, almost any vehicle can be towed with no special additional equipment required. Having a dolly makes more towing options available. (Dad's automotive repair and broken vehicle towing)
Disadvantage - A little more time consuming to load / unload vehicle, its a pain in the butt compared to flat towing. (With that statement, watch the discussion pick up)
Flat towing
Advantage - quick and easy to load / unload
Disadvantage - Initial cost is substantially higher. Tow bar, base plate, brakes. Some of this special equipment is dedicated to vehicle and cannot be used on other vehicles - i.e. base plate.
I do both, flat tow and dolly tow. The decision is usually based on the question: "Do we plan on using the car while traveling?" If the answer is no, then we dolly and usually take our daily driver. If the answer is yes, then we flat tow and take our Saturn or Civic.
While traveling, we'll pull in for an overnight stop and might like to drive into town or something with the car. Usually with the dolly the answer is " I don't fell like unloading the car, maybe next time". With the 4 down, we just unhook and go.
Sometimes, if we think we need both cars, we'll tow one and drive the other..
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 07-16-2016, 08:31 PM   #8
dan-nickie's Avatar
What kind of car do you have? Is it towable 4 wheels down?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 07-16-2016, 10:27 PM   #9
accumack's Avatar
My blue ox base plate, tow bar, patriot brake were way less than a quality tow dolly. We tow a jeep and it takes less than 5 minutes to hook or unhook and I don't have find a place to park the dolly or to backup with it on.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 07-17-2016, 09:09 PM   #10
Thank you all for your input...
I am still undecided..
Joe & Kathy
2017 Dynamax DX3 37BH
Toad: 2016 Ford Edge
2016: days camped 60
2017: days camped 26
towing
