Old 05-29-2013, 03:05 PM   #31
tmmar's Avatar
Originally Posted by B47 View Post
If you want a completely new TPMS then I am sure you can rationize any number of reasons for doing so, but I still do not understand why you would need to buy all new sensors if only one of your present ones is bad.
Is it not possible to buy only one sensor for your present TPMS - if not then that could be a very good reason to give to the DW when she asks why you need a new system when we already have one.
The unit is between 4 and 5 years old and if one sensor is going, I'm sure that others will also be dying shortly.
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-29-2013, 03:16 PM   #32
B47
" ...,I'm sure that others will also be dying shortly." - see I told you that you could rationize a reason for buying a new TPMS
Run it by the DW and your are in.
Old 05-29-2013, 03:23 PM   #33
Rebel702's Avatar
Think I would just give a call to Pressure Pro before throwing out the system. Most tpms companies have support for battery replacement at reasonable cost. JM$.02
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 05-29-2013, 03:36 PM   #34
Denver, CO
garbonz's Avatar
Originally Posted by Camping Buddys View Post
I have the TireMinder from Camping World, got it a month ago for $270 with 4 sensors.
This week is for $246, and if you use the cw coupon for saturday is 10% less.
It works great on my camper.
X2. I have the hawkshead which appears to be identical to the tireminder. Works great and a nice small monitor.
2017 Fuse 23T
Old 06-08-2013, 11:42 PM   #35
Received and installed the system I bought off Ebay. Quick easy install, and it looks very professionally made and has a high quality build..
So far, very happy with it.
Boowho??
boowho is offline   Reply With Quote
Old 06-20-2013, 06:50 AM   #36
Boowho,
Did you end up getting the eezrvproducts system. I saw them last weekend in Syracuse at the Good Sam Ralley. Looked like a nice unit.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 06-20-2013, 09:01 AM   #37
Originally Posted by rgmiller32 View Post
Boowho,
Yes, that is what I got and am quite happy with is.
The only possible fly in the ointment is that one of the sensors on the toad consistently shows a temperature about 15 degrees higher than the other three, even though the toad tires are all inflated to the same pressure (checked with a regular digital tire gauge).
As a test, I'm going to switch two sensors on the toad, reprogram the two into the receiver and see if the problem transfers to the other tire. If so, I'd expect the sensor is defective on the temperature side and will ask a replacement from Tom.
Boowho??
Old 05-17-2014, 05:15 AM   #38
Boowho how do you like the system now after using it for nearly a year? i am looking at the same system you have.
GaryanJane is offline   Reply With Quote
Old 05-17-2014, 12:37 PM   #39
Very happy with it.
One of the sensors MAY be failing, I have to check it out. If so, it's probably still under warranty.
Boowho??
Old 05-17-2014, 12:59 PM   #40
Berkshire 390QS
NO3putt's Avatar
Boowho, is the higher reading on the drivers side of toad? I found out ours reads a bit higher due to the engine exhaust is on that side.
