Old 03-08-2016, 10:05 AM   #21
BamaBob's Avatar
Originally Posted by Phil57 View Post
If you are breaking the bead it instal the dyna beads anyway why not? Not sure what the cost is but removing the sensors on my tires is a PIA. I would much rather have the internal system. I use the beads for my outer duel. I didn't want weights showing. In my opinion the beads are fine. No problem with them.
All that typing and the answer is yes go with your plan.
Thanks Phil!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 03-08-2016, 01:27 PM   #22
rather_b_camping's Avatar
I also use EEZ tpms for my TT and so far have been very pleased with them. I do not believe you need a repeater until you exceed 53' from the sensors to the receiver. Another plus to this brand is it also gives you tire temperature.
2017 Wildcat 36bh
2012 F250 Lariat 6.2 FX4
rather_b_camping is online now   Reply With Quote
Old 03-08-2016, 01:39 PM   #23
All of the TPMS I have looked at have tire temps as a feature. I would not own one without that feature.
Old 03-08-2016, 01:39 PM   #24
We currently have the EEZ RV tpms system (12 tire) ....works great! I find it hard to believe they are not standard equipment on ANY motorhome. We needed the repeater due to the length of our coach....not too difficult to install and customer service was very helpful. Money well spent!
Bob and Veronica
2015 Forest River Charleston 430 RB
2017 GMC 1500 Denali
Harley2152 is offline   Reply With Quote
Old 03-08-2016, 02:46 PM   #25
I use cat eyes they connect the two rear tires. They equalize the air pressure between the tires if one loses to much pressure it will close the one vavle down. Whats nice is you can see the gage if it's losing air with a simple walk around
jrlebaron is offline   Reply With Quote
Old 03-08-2016, 03:12 PM   #26
15berkxl's Avatar
I have a 41 ft and don't need a repeater but I don't monitor the toad. Never had any issues with rear tire
signals.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 03-08-2016, 04:48 PM   #27
Learning
Originally Posted by jbramhall View Post
Which TST system model do you have?
This is the present list of systems available from TST: Tire Pressure Monitoring Systems -*Truck System Technologies
507, 510, internal, external, flow through...?
I have the 507 Flow Through...
2008 Berkshire 36SQ, 2012 Honda CRV
Edward972 is offline   Reply With Quote
Old 03-08-2016, 11:46 PM   #28
7 Year Class A RV'er
Please note that the TST507 is actually the newer model of the TST510. Also, on the repeater, I went a little different path. For about $10, I bought a 120V-AC to 12V-DC converter, plugged it in behind the bedroom TV and hooked the repeater to it in that same cabinet. I know some folks will tell you the repeater is not needed until you hit 53', but you gave to factor in the mass of the coach between the receiver and the toad, etc. in my case, with a roughly 40' coach, a couple of the toad sensors were dropping off, so I added the repeater.
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
Old 03-10-2016, 07:17 PM   #29
gasman94's Avatar
I've got a Tire-Safeguard brand. Had it for 4 or 5 years. Dependable and no repeater need for toad.
Rich
gasman94 is offline   Reply With Quote
Old 04-21-2016, 03:53 PM   #30
TPMS for Berkshire or similar sized motor homes
To close this loop as the OP, I got the TST 507 (I think, flow through, end user serviceable batteries) for the coach and the toad, which in my case is comprised of 2 car dolly tires and the 2 rear tires on the towed vehicle that remain on the road. So far, I have not needed to use the repeater; although, I bought one just in case.
While I'm now more confident that I'll know of a low tire pressure/high heat condition while driving, what I really like is the ability to switch the unit on when I start the coach up and check the cold pressures from the driver's seat without running around with a gauge. I think I speak for us all when I say there's a lot to check before setting off after camping, and this system shortens that list while addressing an important area.
Thanks to all for your input.
Moose
2009 FR Berkshire 390BH
jbramhall is offline   Reply With Quote
berkshire
