Old 05-16-2015, 07:11 PM   #41
TST 507. Leave factory temp setting alone and set each alarm (per axle) for 20 psi over desired pressure and 10 psi under desired pressure. I always pressure my tires at max psi rating anyway and my settings are easy. This is TST recommendations. Mine is great piece of extra assurance.
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
Old 05-16-2015, 07:27 PM   #42
TST recommends 20% over and 10% under. I agree with leaving the factory temperature at default setting, 158 if I remember correctly.
Paulie Boy is offline   Reply With Quote
Old 05-16-2015, 08:30 PM   #43
UmptySquat's Avatar
Rubber valve stem supports on TT or TV?
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 05-16-2015, 08:44 PM   #44
Suggest/highly recommend all metal on both.
Old 05-16-2015, 08:56 PM   #45
vinmaker's Avatar
If you have the cash, I say Yay.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-16-2015, 09:20 PM   #46
Metal if you can. Especially if you use the longer flo-thru sensors.
TST 507RV TPMS
Old 05-16-2015, 11:07 PM   #47
dan-nickie's Avatar
I do my quote 'under' settings for just a couple pounds under. if I have a leak I want to know as soon as possible.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-17-2015, 06:33 AM   #48
gasman94's Avatar
Agree, flow through gets my vote. Also, the Tire safe guard brand has flow throughs with replaceable batteries if that matters to anyone. When I first got my system a couple of years ago, they weren't available. But when they did come out, the company let me upgrade all six sensors for $90.
Rich
gasman94 is offline   Reply With Quote
Old 05-17-2015, 07:52 AM   #49
Lvn2tvl's Avatar
I've been reading about these but not sure if they would interfere with tow vehicle OEM TPMS monitor. TST probably already considered that so is it recommended for all tires or just trailer tires if tow vehicle has OE monitor. I recently had a hot drum on 5th wheel because I didn't set brake controller gain correctly. This would definitely give piece of mind backup for over temp as well.
Lvn2tvl is offline   Reply With Quote
Old 05-17-2015, 07:52 AM   #50
TST also has user replaceable batteries plus you can remove the locks on them and make them even lower profile. If you remove them they will stop transmitting and extend battery life. Otherwise they will last 1 year full time.
TST 507RV TPMS
