Old 08-22-2013, 06:25 AM   #1
Transmission Temp
First off, thanks to all the forum contributors so willing to share knowledge. It's great for this motor coach newbie to have access to so much experience all in one spot!
We're still trying to get up to speed with our new-to-us 2008 Berk 360 QS with the Mercedes engine. Yesterday, while moving the coach across town, I brought up the transmission temp option in the display for the first time. The 147 degree reading caught my eye. Outside temp was around 90. What is the normal range for transmission temperature?
John
John & Rosemary
2008 Berk 360QS
MBE 900-330 w/Allison 3000
Jeep Liberty Toad
JohnKen is offline   Reply With Quote
Old 08-22-2013, 06:43 AM   #2
fonzie's Avatar
at 147 all is OK.....see chart
Name:	transmission temp chart.jpg
Fonzie
Old 08-22-2013, 06:54 AM   #3
TURBS's Avatar
My Allison runs 150 not towing after a 40 mile trip.
Turbs
Old 08-22-2013, 07:03 AM   #4
JBoyer's Avatar
John,
I have your same rig, Mercedes powered. 147 is cool. If you tow in 90 degree, you'll see it edge up well past that. Some tips in the Allison manual you should pay attention to. Don't let the engine lug, downshift. Helps engine and trans temp. If stuck in traffic, slip it into neutral. Don't be afraid to "tell" the transmission what to do.
Just for FYI - watch your engine temp closely. Last month we experienced a failure of the blower fan for the motor. It gets hot very quickly. I had heard a whistle from the engine compartment a few days before the fan failed. Stay tuned into those things. The engine WILL detune when it gets hot and that is scary running down the road.
Enjoy your new to YOU toy. We love ours.
Jeff
2015 Landmark Newport
2015 Silverado 3500hd dually tow vehicle
previous rig
2008 Berkshire pusher
2010 Mini Cooper Convertible toad
2015 Nissan Frontier toad
JBoyer is offline   Reply With Quote
Old 08-22-2013, 07:13 AM   #5
cpaulsen's Avatar
Trans temps usually run about 70-90 degrees above the ambient temps.
cpaulsen is offline   Reply With Quote
Old 08-22-2013, 07:17 AM   #6
acadianbob's Avatar
I think that you have to be careful with "generalisms". The posted chart is becoming dated. Many new vehicles run at much higher temperatures normally. For example, my F150 runs at 195 to 197 degrees normally.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
acadianbob is online now   Reply With Quote
Old 08-22-2013, 07:32 AM   #7
avolnek's Avatar
X2
ATF+4 has an optimal operating range of 160-220. Anything below and the oil isn't providing the appropriate lubricity levels. Anything above and the oil quickly breaks down. It is also important to hit the higher temps as many of then newer vehicles do to make sure to burn off any condensation within the oil from starting and stopping which putting the oil through hot and cold periods. Mine will run 100 degrees above ambient up to 100 degrees then holds pretty close to 200 on the trans temp and only down to about 160 on the low end as my normal numbers.
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 08-22-2013, 07:39 AM   #8
Lynkage's Avatar
My normal trans temp is 190 empty. Towing 17k 210 degrees
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 08-22-2013, 08:14 AM   #9
Brother Les's Avatar
I know that the 7.3 Diesel Powerstrokes 1999-2003 should run about 70 degrees above ambient temps. I shelled my transmission from running it too hot for too long. The suggested solution was to buy a bullet proof transmission with a life time warranty Brians Truck Shop and replace the 7.3 trans cooler with a 6.0 trans cooler which I did.
Brother Les
Old 08-22-2013, 07:02 PM   #10
John
Berkshire 360QS normal temps for the transmission will be from about 140 to 170. I have never seen more than 173 on mine towing my toad in 104 degree temps going through Mount Washington area.
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
