Old 06-11-2016, 04:18 AM   #1
Travel speed-
So I'm looking at a used 390-bh with the 340hp and 2500 trans. I wanted the 360hp- for the better towing capacity and extra hp. but looking at a good deal on the 340.
So 2 questions-
Will I really notice the 20 hp, and 140 ft. lbs. torque difference? and would either one cruse on the freeway at 70-75 when needed to keep up with the trucks.
I look forward to retirement, when I can cruise at 60mph- but now have to get back to work on Mondays.
dave-g is offline   Reply With Quote
Old 06-11-2016, 05:12 AM   #2
indybp57's Avatar
Torque is what gets you up the mountain, so yes I would think 140 ft lbs difference between 2 rigs would be very noticeable. Since most TVs are in the 300-450 range, 140 would be a 33% improvement.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 06-11-2016, 05:24 AM   #3
Diesel engine MH have way more torque than that. I don't know how you could miss something that you never had. Bigger is always better, but at what cost is worth it is what you need to decide.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-11-2016, 05:34 AM   #4
JTN8's Avatar
Travel speed-
I've got a 2014 390BH with the 340 and have never had an issue climbing mountains and or keeping up speed. I set the cruise to 75 when I'm on the interstates and trust me when I say "she's got a lot more in her!" Some may say I'm crazy but I've seen 85 plus in mine when passing in the left lane and traffic is flowing. I tow a Cadillac SRX 95% of the time so between the toad, people and belongings I'm just under the max GCVWR and still notice that the coach has more torque and power than needed. Fuel mileage on the 340 is amazing! I usually average between 10 and 11.5 MPG and that's fully loaded and again speeds around 75. If you set the cruise to 60 65, you'll see MPG's in the 12's. If it's a good deal, don't let the HP and TQ bother you.
Just my opinion!!!
Jason
2014 Berkshire 390BH
2011 Cadillac SRX (toad)
FB
Old 06-11-2016, 07:50 AM   #5
accumack's Avatar
Make sure you get it weighed before signing anything. I have the 340 and it does ok you will slow down going up hills in either one. We pass trucks all the time going up hill.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 06-11-2016, 09:11 AM   #6
ernest917's Avatar
I'd rather have the 3,000 transmission.... It's stronger and allows u to tow more... I have it and love it....
ernest917 is offline   Reply With Quote
Old 06-11-2016, 10:07 AM   #7
mikeborny's Avatar
I dont think i have ever seen MPG above 10. Just drove from Cleveland to Denver and was averaging 9.9 MPG until we hit Nebraska and I set the cruise at 70. I travel with 5, and 2/3 water, full propain. I tow a 4 door Jeep Wrangler. There would be no problem cruising at 75.
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 06-11-2016, 10:46 AM   #8
ernest917's Avatar
I try to keep my speed around 60-63mph - that seems to be the sweet spot for my rig.... I consistently get between 9.5 - 12.9 and that pulling our toad....
Old 06-11-2016, 11:15 AM   #9
mikeborny's Avatar
How much difference do you see while running generator and roof AC?
Old 06-11-2016, 11:16 AM   #10
Dave-g
I have a 2011 RB with the 340. I have had it for 4 years now. I have pulled a Buick Enclave weight 5200. I went to a two door Jeep weight 3800. We traded the Jeep for a MKX Lincoln weight around 4000 ( I am guessing as I have not weighed this one yet. We full time so we are loaded up. My total estimated weight is 34500 lbs about 1500 overweight.
We have traveled to Tx , Florida ,NY, Michigan. Up and down the east coast. We have gone through the mountains. We have not traveled west yet but plan to.
We have not hit anything that I was worried about getting over ( with the exception of a nasty grade in NY on a two way). I would rather have the 360 with the 3000 Trans but I don't need it. I feel I can go anyplace I choose with the set up I have.
The trick is you must drive it. This is a big rig and setting back enjoying the scenery is fine but to get up the big hills you need to pay attention. Use that Allison Transmission to get up the hills. You need to keep the rpm's at 1800-2000. Don't be afraid to downshift. The computer will not let you do anything that will damage the motor or transmission.
I usually travel with at least a half tank of water most of the time more than that.
If it's a good deal grab it. You will not be sorry. I'm not.
travel
