Old 03-03-2015, 01:38 PM   #11
Thanks Craig.
I assume 2011 and 2014 have the same chassis?
Alex and Valerie
2014 Berkshire 400BH
AlexG is offline   Reply With Quote
Old 03-03-2015, 02:34 PM   #12
2011 Berkshire 390BH
Superchief's Avatar
I believe that to be correct. Raised Rail, etc. One side of the bracket gets bolted to the frame and the other side is a "U" bracket that goes on the steering rod.Click image for larger version
Name:	ImageUploadedByForest River Forums1425414807.808777.jpg
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 03-03-2015, 02:43 PM   #13
Craig,
Thank you very much
Alex
Alex and Valerie
Old 03-03-2015, 02:47 PM   #14
silver's Avatar
Originally Posted by Superchief View Post
Alex
I got the TC6011 and the TC35270 (It is the largest one). I have a 390BH-2011 . Hope that helps.
Craig
Superchief,
My 2008 Berkshire has a steering damper installed by Freightliner. Did your 2011 and did you remove it to install the true center?
silver is offline   Reply With Quote
Old 03-03-2015, 03:00 PM   #15
Superchief's Avatar
Hi Silver,
Didn't have to remove anything to install it, except the bolts holding the bracket to the frame. I don't believe I have the damper.
Craig
Craig
Old 03-03-2015, 03:24 PM   #16
Superchief's Avatar
Alex,
I tried to find some E-Mails that I had sent to Gasman and Mmnsc about my installation problems, in the past, but they disappeared. I don't know if this is applicable to you or not. I will give you the short version. I had an impact hammer when I started, but it was not big enough to loosen the bolts from the frame, so I could install the bracket. I ended up going to a truck garage and they installed the bracket for me ($40). If you install it yourself, you will need a high end torque wrench ($100). I also had to buy a step drill to install the button ($45). I also purchased some other small wiring things ($20). I know that Mmnsc (Marty) got his installed by Camping World for less than $100, but he doesn't have the nice new tools that I have. 😀👍 Hope that helps!
Craig
Craig
Old 03-03-2015, 06:14 PM   #17
Mmnsc's Avatar
Alex
I was fortunate to find a deal through Camping World. They had a free installation when buying the unit and bracket. The unit was on sale so i made out on both ends. The out the door cost $1150 and was done in less than 4 hours.
After hearing the horror story from Craig on his 3 day installation i knew there was no way this would be a DIY job for me. CW did a nice job of hooking up the electric and mounting the button on the dash. Good luck with what ever route you go.
Marty
Mmnsc is offline   Reply With Quote
Old 03-04-2015, 03:38 PM   #18
I can get the unit with brackets online for about $915 shipped. I was quoted 1 and 1/2 to 2 and 1/2 hours of labor to have it installed @ $125/hour. Still beats Camping world "sale" prices even if installation was included of $1010 + $98 + tax.
Thanks for the input,
Alex
Alex and Valerie
Old 03-04-2015, 03:52 PM   #19
Mmnsc's Avatar
Having someone do it for you no matter what it cost will be a blessing. I know you will see a marked improvement when in a cross wind situation.
Old 03-04-2015, 04:23 PM   #20
I definitely hope so. I read so much about things that I can do to improve handling and tracking. I regularly travel through NE and WY. Last December we were hit by 50 to 70 mph cross winds when we crossed into WY.
I was very disappointed that there are no track bars for Berks.
Alex and Valerie
wiring
